frame question
Old Dec 27, 2009 | 05:07 PM
SNSTER's Avatar
SNSTER
frame question
any difference in the frames between a late model 77 F-250 and 78 79 frames?
Old Dec 27, 2009 | 09:03 PM
93F22A6's Avatar
93F22A6
I'm almost positive that the 77.5-79 frames are all the same basically. The early 77 where the highboy frames. Not entirely positive here though.
Old Dec 27, 2009 | 10:42 PM
tenforty_2's Avatar
tenforty_2
This is the same thing that I have heard. The early 77's (77.5) had the more narrow frames like the 73-76 and the later 77's had the same frame as the 78 & 79. I looked at a rolling frame one time that was a 1977 model year and it was the same width as my 79.
Kirk
Old Dec 27, 2009 | 11:43 PM
1977f250's Avatar
1977f250
Same as 78/79, different front cross member than pre 77.5, and same power steering setup as 78/79, to name a few differences.
Old Dec 28, 2009 | 02:22 PM
jesse789's Avatar
jesse789
I heard there is a vin## on the passenger side frame rail somewhere below the alternator. I have a 1975 ford f250 and i can't find a vin # anywhere the door vin plates are gone and the build sheets under the seat are from a 2wd the only numbers on the truck is a body serial# plate on the firewall right by the brake booster. if anyone knows where else ford put the vin # on these trucks?
Old Dec 28, 2009 | 04:54 PM
tenforty_2's Avatar
tenforty_2
The frame does have a vin on it, but is probably covered up with rust and or paint. On this same subject, I found it interesting when I stripped my frame I found a part # (D9???) stamped on it as well.
