78 wont spark
Old Dec 19, 2009 | 05:36 PM
coz's Avatar
coz
78 wont spark
Ok here we go.
owned truck for two days Ran good when i got it home now no spark.
Replaced pickup in distributor
Icu
starter relay
Cleaned ground behind icm
I have power to icm key on
I have power to icm on key start
power to both sides of the coil
Put light on Tach test it doesnt flash, it lights up when key is in on position and stays solid while cranking. (you can see it flickering a bit from the starter draw)
Anybody have any further input
Thanks
Old Dec 19, 2009 | 05:41 PM
FLATFORD1976's Avatar
FLATFORD1976
did you say you replaced the icm
Old Dec 19, 2009 | 06:34 PM
montana_highboy's Avatar
montana_highboy
Bad coil.......
Old Dec 19, 2009 | 07:20 PM
coz's Avatar
coz
yes replaced icm have 3 on hand all same results.... will try coil
Old Dec 20, 2009 | 05:54 PM
coz's Avatar
coz
Changed out coil........... no results
Old Dec 21, 2009 | 07:52 PM
terryk78's Avatar
terryk78
Mine did that also. I had a bad wire from the coil,it had a few broken wires
Also the connection to the distributor had some broken wires, just enough where it wasn't making spark
Old Dec 28, 2009 | 05:28 PM
coz's Avatar
coz
Ended up being a bad ground wire on the disributor somewhere in the taped wires. I replaced the wire and did the old chevy camaro hei module trick... Night and day
