Another Fire Loss!
Old Dec 27, 2009 | 11:45 AM
MADVAN's Avatar
MADVAN
Another Fire Loss!
https://www.ford-trucks.com/forums/9...g-in-pics.html
Bill
Old Dec 27, 2009 | 12:20 PM
Action4478's Avatar
Action4478
Had me worried for a sec.. I saw that thread ,, not good ...
Old Dec 27, 2009 | 01:49 PM
WALJON's Avatar
WALJON
That is not good..... thank you for posting that Two weeks ago or so I posted about my block heater cord arcing out under my truck and burning off when this happened it looked like a transformer on a hydro pole arcing out I could see how it would catch the motor on fire especially if there is an oil leak near by.
By the way I plug into a GFI receptacle and it did not trip figure that one out
Old Dec 27, 2009 | 02:09 PM
arkredneck's Avatar
arkredneck
gfi work by detecting a difference between the hot wire and the neutral wire so unless there is a direct short the gfi won't trip if you would have thrown some water on it then it would have probably tripped out the gfi... i'm a electrician and have never seen a gfi that was bad that would still work and not trip all the ones i have ever seen just won't reset if bad
Old Dec 27, 2009 | 02:12 PM
MADVAN's Avatar
MADVAN
A GFI's only job is to sense currents to ground.
Its a imbalance of the hot and neutral.
It does nothing to protect from shorts, over currents ect
of a ac circuit.
Some info
How Ground Fault Protection Works | DoItYourself.com
Bill
Old Dec 27, 2009 | 03:22 PM
LMS Residential's Avatar
LMS Residential
that sux, try to look at the bright side that it wasnt parked inside causing damage to the building or the obvious that no one was in it. Good luck with the claim and replacement truck.
Old Dec 27, 2009 | 06:15 PM
scatgo's Avatar
scatgo
This stuff with the fires is starting to get me nervous. You should see what my extension cord looks like. One of the plugs on it is all black and melted. Arced like hell when I plugged it in.
Old Dec 27, 2009 | 07:12 PM
79f-250custom's Avatar
79f-250custom
Originally Posted by scatgo
This stuff with the fires is starting to get me nervous. You should see what my extension cord looks like. One of the plugs on it is all black and melted. Arcs like hell when I plugged it in.
dood the cord fore the block heater is like 25 bux.
fix it before its you 250000 dollar house.
Mitch
Old Dec 27, 2009 | 07:45 PM
scatgo's Avatar
scatgo
Mitch
Its on the way. And umm its a 500000 dollar house.
Old Dec 27, 2009 | 09:19 PM
strokin'_tatsch's Avatar
strokin'_tatsch
no wonder your truck has no mods.....
Old Dec 27, 2009 | 09:32 PM
scatgo's Avatar
scatgo
Now you know why........................
Old Dec 27, 2009 | 09:35 PM
oldbird1965's Avatar
oldbird1965
I think that's called one-up-menship or something like that.
Old Dec 27, 2009 | 09:40 PM
scatgo's Avatar
scatgo
Yes, and also known as just breaking b##ls.
Old Dec 27, 2009 | 10:20 PM
oldbird1965
Well then, my house is a cool mill.
Old Dec 27, 2009 | 10:53 PM
strokin'_tatsch
just think what 500k would do to a PSD!!! Lol.
