Help with coolant code P0128
Old Dec 27, 2009 | 11:44 AM
yellowboy's Avatar
yellowboy
My service engine light is on and it reads
P0128 "coolant theromostat - coolant temp below thermostat regulating temperature".
It's an 04 Explorer with the original coolant, it's full (plan to change it this spring). Any suggestions on what to try ? Thanks
Old Dec 27, 2009 | 01:05 PM
projectSHO89's Avatar
projectSHO89
Usually, that means the thermostat isn't closing properly.
If you have adequate heat, your coolant level is correct, and you don't have a pending emissions test, you can probably wait until spring and replace the thermostat at the same time as your coolant.
Otherwise, do both jobs sooner.
Old Dec 27, 2009 | 02:41 PM
yellowboy's Avatar
yellowboy
Thanks, is the thermostat at the radiator where the large hose from the block connects ?
Old Dec 27, 2009 | 08:34 PM
06silvercrew's Avatar
06silvercrew
No, its where the UPPER hose comes out of the motor/intake.
Old Dec 27, 2009 | 08:48 PM
deadeyedevon's Avatar
deadeyedevon
i have the same code on my 03 and the temp never gets but a lil bit higher than the C on the gauge, i was told its the thermostat, makes sense, i have crap heat in it. its sooo damn cold out i dont wanna swap it out.
Old Dec 27, 2009 | 11:19 PM
steve(ill)'s Avatar
steve(ill)
the thermostat is closed at startup and lets the motor warm up quick. After 4-5 minutes on the road, the thermostat opens as the temp goes up, and the gauge should stabalize at about 50% of needle travel on the gauge. If it takes forever to rise, or dont go up more than a little off the Cold mark, then the thermostat is probably bad-- and you have no heat.
Old Dec 28, 2009 | 01:40 AM
liftnw8z's Avatar
liftnw8z
Mine (a 97 4.0L) will warm up and throw plenty of heat, but the gauge bounces around a little within the operating zone - sometimes dropping way down toward "C", but rarely going up over halfway (no threat of overheat). It threw the check engine light recently, but I've yet to pull a code on it and see exactly what it is. That's priority for this week with a trip coming up to be sure it's ok and/or take care of whatever it might need..
Old Dec 28, 2009 | 04:22 AM
yellowboy's Avatar
yellowboy
Thanks guys and one more question, where is the best place to drain the coolant from ? I see a white cap on a black tee on the passenger side of the vehicle to the side of the radiator-- (not sure if that is even in the pipeline)--or is there a better place ?
Old Dec 28, 2009 | 07:14 AM
projectSHO89
There should be a drain plug on the bottom of one of the radiator tanks.
Other alternative is to pull the lower radiator hose and drain the system from it.
Old Dec 28, 2009 | 05:09 PM
deadeyedevon
that kinda sounds like you might just have air in the coolant lines, did you try to burp the radiator
Old Dec 28, 2009 | 05:42 PM
liftnw8z's Avatar
liftnw8z
I haven't yet, no. I did hear some gurgling coming from somewhere too, which could confirm that suspicion. Wonder how I'd have managed that as I've not had any part of the system apart for any reason...?
tbar1963
6.2L V8
Apr 1, 2017 10:49 AM
Markus Steele
6.4L Power Stroke Diesel
Jul 14, 2016 08:16 AM
Goldielocks
Apr 6, 2016 07:08 PM
trukerdanz
1983 - 2012 Ranger & B-Series
Apr 2, 2016 09:07 AM
arco777
Modular V8 (4.6L, 5.4L)
13
Apr 22, 2011 08:21 PM
