1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Won't Go Into Overdrive
Old 12-26-2009, 02:14 PM
emueller's Avatar
emueller
emueller is offline
I have a 2001 F250 Superduty - 5.4l 4-speed auti 4X4 Manual Hubs.
Lately, when cold, the truck is not dropping into Overdrive at highway speeds as it normally does.
I am not getting any check engine lights or any kind of other indications other than the RPM's are higher than usual and my milage is very poor.
Any thoughts?
Old 12-26-2009, 05:23 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,580 Likes on 1,058 Posts
Does it go into overdrive once it has warmed up? There is logic in the PCM that does not allow the torque converter to lock when the trans is cold, but it should shift to overdrive.
Old 12-26-2009, 07:09 PM
fordtech08's Avatar
fordtech08
fordtech08 is offline
have you checked fluid level?
siringo1880
2004 - 2008 F150
09-22-2015 10:24 PM
devink
05-04-2015 10:43 AM
bigvinnie
11-06-2005 02:34 AM
mantta
04-26-2001 03:31 PM
Charles
07-15-1999 11:45 AM
Quick Reply: Won't Go Into Overdrive
