AOD Transmission
Old Apr 25, 2001 | 05:47 PM
mantta's Avatar
mantta
AOD Transmission
My 88 F-150 has an AOD that was installed later to replace the Mazda standard shift transmission. On the oil pan there is stamped Ford Automatic Overdrive, it also has stamped in large letters on the pan "METRIC". does this have any significance other than that it may have all metric sizes? How about shifting speeds and all? This one shifts into overdrive at about 37 mph. I thought that it may have been made for foreign sale. My Crown Vic has the same transmission and it does not hav the "METRIC" stamped into the pan.
Old Apr 25, 2001 | 11:36 PM
sweet82's Avatar
sweet82
AOD Transmission
it should fit
Old Apr 26, 2001 | 12:02 AM
corlucci's Avatar
corlucci
AOD Transmission
My 1995 F-150 has the 4R70W (the electronically controlled version of the AOD) and the pan says METRIC, so I assume it just means everything inside is metric. I wouldn't read anything into it.
Old Apr 26, 2001 | 01:40 AM
hotrodford_88's Avatar
hotrodford_88
AOD Transmission
Mantta,
Did you do the swap or was it before you got the truck? If so can you clue me into what all was involved in the swap? Also how hard was it to do the swap. I'm looking into this same thing for my truck, mainly becuse the clutch is starting to kill my left knee, especially in Houston, Tx traffic.
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
Old Apr 26, 2001 | 09:21 AM
mantta's Avatar
mantta
AOD Transmission
I did not do the swap, It had been done before I bought the truck. Whoever done it done a very nice job. The only way I could tell is the clutch master cylinder is still there. Otherwise it is perfect, including the shifter on the tree and everything. Ive only done one of these swaps before and it was on a 51 Ford, I yanked the automatic and put in a 3 speed stick. It was fairly easy because I had a complete car to get parts from.
Old Apr 26, 2001 | 03:31 PM
bjoern's Avatar
bjoern
AOD Transmission
desperado_18_2000
Apr 7, 2025 08:16 AM
DASZU
May 13, 2011 08:12 AM
paul123
2009 - 2014 F150
19
Oct 9, 2009 01:00 PM
Major94
Aug 29, 2009 10:08 AM
TommyZ1
May 1, 2009 07:14 PM
