Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Alternator 05 Escape???
Old Dec 26, 2009 | 01:47 PM
Ryanr's Avatar
Ryanr
Alternator on the escape died.Holy crap how the hell do you get this thing out??Is there any tech files for tips and tricks to get this thing out.Iam guessing engine has to be jacked up.Any help would be great thanks.
Old Dec 26, 2009 | 04:22 PM
87 XLT's Avatar
87 XLT
I have no idea on how to get the alt out, but are you sure it's shot?
A quick look at the charge circuit wiring diagram when i had a not charging problem told me which fuse to check.
Replaced the fuse & problem solved.
Make sure you dont simply have a blown fuse.
Old Dec 26, 2009 | 07:30 PM
FireMe's Avatar
FireMe
How it comes out depends on which engine you have......
Old Dec 26, 2009 | 08:34 PM
Ryanr's Avatar
Ryanr
The engine is 3.0v6,almost looks as if transaxle,right tire,weather shield need to be removed and maybe resenator??.They sure got that thing jammed in there.A blown fuse would cause the battery not to charge??The new battery wasn't getting charged when i checked with a meter.Please help with which fuses would cause this,thanks for the help fellows.
Old Dec 26, 2009 | 08:42 PM
87 XLT's Avatar
87 XLT
I have the factory wiring diagrams for all my Fords, but I dont have an 05 Escape.
Take a look at the fuse list in your owners manual, is there a fuse labeled "generator/voltage regulator"?
Old Dec 27, 2009 | 11:07 AM
FireMe's Avatar
FireMe
You should have power at the black with yellow wire at the voltage regulator. If not, check fuse 9 in the battery junction box. If you have power there, then you will need a scan tool with PID capability to monitor the charging system operation, as it is controlled by the PCM on this vehicle.
To remove the alternator:
Disconnect the battery.
Remove the RF wheel.
Remove the splash shields.
Remove the axle shaft.
Remove the belt.
Remove alternator electrical connections.
Remove air duct.
Remove alternator shield.
Remove alternator mounting nuts and bolts .
Remove alternator through wheel well.
Sometimes you don't have to remove the axle shaft, but it is much easier without it there. Also, some people remove the alternator shields with the alternator still in the vehicle, and some people remove the alternator then take the shields off.
Jay
Old Dec 27, 2009 | 08:04 PM
Ryanr's Avatar
Ryanr
Thanks Jay.Fuse is good,old ALT out, new ones in.ALL IS GOOD THANKS.
Old Dec 30, 2009 | 07:59 AM
tcesni's Avatar
tcesni
Good luck with your alternator and I hope your replacement is a quality part. I went through 3 aftermarket alternators in 3 months before finally getting a good one.
Old Dec 30, 2009 | 09:55 PM
Ryanr's Avatar
Ryanr
Well went to ford to get the replacement.So hope its all good.wouldn't want to make a habit of doing this job..
Old Dec 31, 2009 | 04:41 PM
bmuhlbach's Avatar
bmuhlbach
my neighbor got Autozone starters for his s10 the thrid one worked out to be ok!!!!!!!!!!
Old Dec 31, 2009 | 09:51 PM
tcesni's Avatar
tcesni
Mine came from NAPA. The first two were Bosch and quickly crapped out. The third was from a different manufacturer and has been fine.
artieb
Jan 25, 2016 10:59 AM
npccpartsman
13
Jan 10, 2011 09:08 AM
rtcalabrojr
Mar 14, 2009 07:38 PM
