schaeffers fuel additives
Old Dec 26, 2009 | 11:52 AM
pete98cobra's Avatar
pete98cobra
Does anybody have any experiance using their fuel additives ?
Thinking about trying it when I make my next order.
Old Dec 26, 2009 | 12:08 PM
jkidd_39's Avatar
jkidd_39
I run there diesel additive. It does the same thing as DK as far as i'm concern. I just like that the 5 gallon bucket treats 5000 gallons for $170.
I also have a 5000 gallon tank tho haha
Old Dec 26, 2009 | 04:23 PM
F250_'s Avatar
F250_
I've been using it for about 4 months, and it works as well as the DK. As a Schaeffer rep myself, I'm still testing it and need to do some additional side-by-side comparisons for my own curiosity's sake. I know that the Schaeffer Diesel Treat has excellent acid neutralization properties and can perform a very high degree of water stabilization (keeping water from separating out of the fuel in your tank).
Historically, I ran the DK for over a year, and then ran the Stanadyne for a short time, then ran the Opti-Lube XPD for over a year. After running the third tankfull of fuel on the Diesel Treat, I can tell a difference in SOTP performance. Though I honestly don't often put a lot of in the SOTP "meter", I was neither looking for nor expecting the feel any performance difference, and it is something that has slowly dawned on me over the past couple of months. I've even run a tank or two without the additive and can definitely tell the difference.
Old Dec 27, 2009 | 09:20 PM
white Buffalo's Avatar
white Buffalo
Some additional info to what has been already posted:
Schaeffer's Dieseltreat 2000 (summer Blend) scored much better for added lubricity that DieselKleen. Here's a chart that many have seen before, done by Southwest Research & DieselPlace.com
For those living up North here is a Cold Flow test done with Schaeffer's Winterized Dieseltreat. Brought the gelling point down a good 25 degrees. Much more cost effective than running a mix of #1 and #2.
Hossfly05
Feb 20, 2015 09:28 PM
ssolid
Jul 18, 2014 08:13 PM
1L243
15
May 10, 2014 12:55 PM
droffan
Jun 12, 2013 10:22 PM
Cheapteen979
6.4L Power Stroke Diesel
23
Dec 28, 2011 07:59 PM
