Rear fueltank query....
In the Ranger F150 we are looking at, it has a tank in the cab, and one under the tray, should the switch that selects the rear or front tank cut the fuel flow, or does it only switch between sender units? Should the fuel be able to flow from both tanks at once?
Thanks,
Shane
Thanks,
Shane
The dash fuel tank switch works in conjunction with the fuel tank selector valve and solenoid assy which is mounted on the frame rail.
If fuel is flowing from both tanks at once, this valve is the likely culprit. There are two different valves, it depends on what year the truck is.
You didn't say what year this F150 is. F150's with the In-Cab were made 1975/77.
It's not a 1978 or 1979, because the last year for in In-Cab fuel tank was 1977.
The only time I buy aftermarket repro parts is...if I cannot find Genuine Ford Parts.
The only repro parts sellers I've ever bought anything from are Dennis Carpenter and Dearborn Classics...both for 1963 Galaxie parts.
D5TZ9189B .. Fuel Tank Selector Valve & Solenoid Assy / 3 Ports / Marked: D5TF-9F271-AA / D5TZ9189B replaced D5TZ9189A / Obsolete
Fits: 1975/77: F100/350 & E150/350 (Econoline).
Sorry, no Ford Dealer or obsolete parts vendor has either part number.
Joel Cassell
23
08-01-2015 02:33 PM
PintoGuy
06-12-2015 10:41 AM
tkisling
12-25-2013 09:47 AM
izmepeggy
20
12-18-2012 12:14 AM
