Transmission Fluid
Old Dec 26, 2009 | 06:28 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Originally Posted by 0gers
I personally wouldn't go for the flush. The replacement fluid will have detergents in it to clean the tranny. One other tip I have is to drain the sump via the dip stick tube using a siphon. That way when you drop the sump most of the fluid is gone and you make less of a mess. Oh and do it when the engine and tranny are warm.
OK, I'm confused, what's wrong with flushing? I took my '04 to the dealer at 40k and had it flushed. I'll do it again at 80K and again at 120K..........
This seems to be the Ford dealer's preferred method so therefore, FMC must OK with it as well.
I realize that each flush is about 10k over due, but the truck performs more like a car and does absolutely no towing.
Tim
Old Dec 26, 2009 | 06:41 PM
fordtech08's Avatar
fordtech08
there is nothing wrong with flushing it, but just because you treat it like a car and don't tow which would put you in severe duty cars get flushed at thirty, just somrething to think about
Old Dec 26, 2009 | 11:31 PM
tseekins's Avatar
tseekins
Yes sir, you are correct in that statement. But, most people don't bother at all until it's grossly discolored, smelly or the tranny simply shows signs of failure.
Tim
dssocialwrk
Nov 30, 2018 04:55 AM
myakkacracka
13
Jun 16, 2016 11:33 AM
Hammer6905
Jan 23, 2015 11:13 AM
bhirtz
Aug 27, 2011 02:38 PM
CrazyHorseUK
May 26, 2010 08:09 AM
