Help on trailer lights...
Old Apr 3, 2010 | 01:28 PM
ngng's Avatar
ngng
Does the "Trailer Tow Battery Charge" fuse also handle the interior accessory lights? My lights don't turn on inside of the trailer.
Old Apr 3, 2010 | 02:46 PM
SpringerPop's Avatar
SpringerPop
I believe so. However, I don't know how your manufacturer wired it.
That pin in the plug is only "hot" when the engine is running (when the alternator is able to charge the trailer battery), and your interior lighting is likely connected to that battery circuit.
Maybe the battery is dead?
Maybe the battery is not there at all?
Kinda' old thread, huh?
Pop
Old Apr 3, 2010 | 02:50 PM
ngng's Avatar
ngng
Pop
The 30amp maxi fuse is missing, so I'm gonna replace it. I was just curious if there was another fuse I should have been looking for.
Yeah old thread, I search before I post.
Old Apr 3, 2010 | 02:53 PM
SpringerPop
Also Fuse 24, it's a 10-amp. It likely is the fuse for the relay's coil, not it's power contacts source, which is the 30-amp Fuse 16.
Kudos for using the search function!!
Pop
Old Apr 3, 2010 | 03:01 PM
SpringerPop
BTW, you know you have to have a small, add-on "doghouse" with two relays inside, which is part of the trailer-towing package, for this all to work?
If I recall correctly, every signal output (except ground) on the truck's trailer-towing plug is fed out through a relay to protect the truck's wiring in the event of a mis-wire or short in the trailer's wiring.
Do you read wiring diagrams? If so, I'll PM you a source for the 2000's stuff.
Pop
Old Apr 3, 2010 | 03:07 PM
ngng's Avatar
ngng
Pop
I read that that, I have the relays already:
I can read some diagrams, would appreciate anything. My 2000 didn't come with any manuals or anything.
Old Apr 3, 2010 | 03:22 PM
SpringerPop
OK, photos are always good! From that one, I can see that you have the required "doghouse". It's the little box to the left of your main under-hood fuse/relay box.
Inside you have to have two relays. When they add the trailer-towing package, they don't put at least one of those relays into it's socket. If you need one, it's Ford p/n FOAB-14B192-AA, but any good Bosch automotive relay will plug right in (you may have to trim off a mounting tab).
You know that you can download an Owner's Manual free-of-charge? It has both diagrams (there's another fuse panel under your instrument panel), and descriptions what each fuse does.
https://www.fleet.ford.com/maintenan...ls/default.asp
Go check to be sure you have the relay in the doghouse, and check to be sure that Fuse 24 is good. It's in the other fuse box, and is the red, 10-amp one that is in the right-most row, third spot down from the top. Note that not all spots are filled, so the one you want is the second "installed" fuse down, right beside another red one in the middle row.
PM sent to you.
Pop
lakewood
Apr 26, 2011 11:06 PM
2kcrewcab
6.4L Power Stroke Diesel
13
Apr 7, 2011 06:04 AM
John Puig
Dec 7, 2010 05:20 PM
ds086121
Mar 2, 2010 11:06 PM
birchy
Jul 16, 2009 09:16 AM
