Headlight Questions
Old Dec 24, 2009 | 11:18 AM
dwrestle's Avatar
dwrestle
Headlight Questions
Hey guys either my headlights are dim, and need replaced, or they need adjusted. Is there an easy way to adjust the angle of the lights on these model Fords?
Old Dec 24, 2009 | 11:39 AM
Swatter's Avatar
Swatter
Dont know the spec's, but something like you park so many feet from a wall. Draw a vertical line a horizontal line so many feet high etc.. Again not sure of all the spec's, but if you do it incorrectly you'll be blinding on coming traffic.
Old Dec 24, 2009 | 05:04 PM
dwrestle's Avatar
dwrestle
Thanks for the help, but I actually meant is it possible to do so on our model trucks, and if so how is it done? Like what tools do I need, and where is the adjustment made at?
Old Dec 24, 2009 | 06:29 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Aimed straight ahead and 2 degrees down.
Halogen headlamps were standard on the 1980 and newer.
Old Dec 24, 2009 | 07:15 PM
first today's Avatar
first today
There are adjustments for up and down, in an out.(left and right)
It is a standard phillips screwdriver. They are by the trim ring that holds the headlights in.
Old Dec 24, 2009 | 08:02 PM
dwrestle's Avatar
dwrestle
Sweet thats exactly what I wanted to know. I didn't even know you could adjust the headlights until I saw my uncle adjust his on a 01 Grand Cherokee. He had to use an allen wrench, so I figured if an 83 F-150 could be adjusted it would probably be easier than his Jeep. Thanks guys.
Old Dec 24, 2009 | 09:33 PM
81-F-150-Explorer
Yes, they even have special headlamp adjusters that can be attached to the headlights, that use mirrors, levels and marks, and the new ones even use lazer beams to get them exactly right. I used them before in autoshop when I was a youngster.
Simular to how they do a four wheel alighnment nowdays....
Old Dec 25, 2009 | 08:57 AM
bashby's Avatar
bashby
Whiter Whites, Brighter Brights .: Articles
jbljohn
1983 - 2012 Ranger & B-Series
May 4, 2013 09:02 AM
Deluxe06
Sep 19, 2012 04:55 AM
Tuxedo Scorpion
6.7L Power Stroke Diesel
Jun 12, 2012 10:38 AM
3KIDDAD
Jan 21, 2007 10:54 PM
boyadam1
Jun 27, 2003 03:58 PM
