Some basic care info in Ford videos
Here is some basic info on caring for your 6.0L truck.
<TABLE style="WIDTH: 262pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=350 x:str><COLGROUP><COL style="WIDTH: 262pt; mso-width-source: userset; mso-width-alt: 12352" width=350><TBODY><TR style="HEIGHT: 25.85pt" height=34><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 262pt; HEIGHT: 25.85pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=34 width=350>http://www.motorcraftservice.com/vdirs/servicetips/dieselcare/index.html</TD></TR></TBODY></TABLE>
Click on the 6.0L label and watch the "lead-in" video until the end (or click on the "right arrow" to take you to the end). At that point, you will have a menu of things to choose from.
One item to note is the oil information. When you click on it, you will see an oil application chart about 30 seconds into the video. In that chart you can see what Ford has to tell us about the 5W40 temperature "range of application". It says -20*F to over 100*F. This was a question awhile back (ie whether or not Ford actually acknowledged the use of 5W40 in this wide of a range).
Received 1,449 Likes
on
The bars for 15W40 and 5W40 both end with arrows on the right side, indicating the acceptable application continues toward the right and higher temps.
The bars for 10W30 and 0W30, both end square. Meaning the end of the acceptable range.
I know the 15W goes a little farther right than the 5W. I don't know why, and it doesn't make sense to me. They are both 40 weight base stocks, and it's well known that synthetic withstands heat better than conventional. I can't guess why they slanted the chart toward 15W like they did.
on
Look at the chart again. It helps to pause the video on the chart.
The 5W40 has an upper limit of 100*F and the 15W40 exceeds 100*F which again tells me the 15W40 has more high temperature margin for this particular engine.
Just trying to call a "spade a spade"!
Here is a link to the Motorcraft 5W-40 synthetic product page, where they recommend it for all Powerstrokes:
http://www.fcsdchemicalsandlubricant...gory=Motor Oil
"Motorcraft® SAE 5W-40 Full Synthetic Diesel Motor Oil is recommended for use in Powerstroke® diesel engines over a wide temperature range, from -20°F (-29°C) to over 100°F (38°C)."
and for comparison, here is the page for 15W-40:
Multi-weight oils use hydrocarbon-polymer chemistry to "stretch" the base weight to the second weight. And with all other things being equal, a 15-weight oil performs better in high temperatures than a 0-weight or 5-weight oil.
Now, given that synthetics (supposedly) perform better than conventional oils, some of this is no longer current. (i.e. things are not equal).
But what I was told, way back when, was that older 10w40 oils were poor oils to use because the (then) current base oils weren't of sufficient quality to be "stretched" to a 40-weight oil. That's probably why 20w50 oils had some brief popularity in automotive engines in the late '80's and 90's.
These days, better quality base stocks allow 15-weight oil to be "stretched" with little difficulty. And synthetics allow 5-weight group-IV (the latest group?) base stocks to be stretched without harm. But in super-high-heat applications (such as in the American Southwest (AZ, NM, SoTX, SoCA), where daytime ambient temps in summer can exceed 120 degrees), a 15-weight base stock oil will probably perform better in most scenarios, especially those where the truck's owner is somewhat less than OCD on maintenance.
-blaine
