Permanent Fixes For Common Rust-Outs
Old Dec 24, 2009 | 04:21 PM
willymakeit's Avatar
willymakeit
As wolverine asked, and I seen it on ashow here lately. There is an electric device used to stop rust. It is used a lot in the marine industry. Any body have any experience ?
Old Dec 24, 2009 | 04:35 PM
tinman52's Avatar
tinman52
Welder User
Rust is an EVIL thing....I battle it almost every day. IMO there are two types of rust........active and inactive. Active rust is the type usually trapped between 2 pieces of metal as described above. It is still actively eating the metal and usually still wet. Trapped moisture is your enemy, guys. I believe keeping those areas open is the best defense......sometimes I will make extra drain holes in the inner panels so the joints can dry out..sealing them up may work also, but what happens if your seam sealer fails? Trapped moisture. Cab corners, door bottoms, etc will last forever if you keep them clean. Actually keeping Everything clean is a good defense.
Inactive rust is just that, inactive until it gets wet. Surface rust. It doesn't really hurt anything but looks bad (to most people).
All just my 2 cents....t/m
willymakeit
Rust control
Went on line. One of the places is called Rustterminator. Around 300.00 Curious if anyone has any experience with these products?
Old Dec 24, 2009 | 05:11 PM
49fordpickumup's Avatar
49fordpickumup
If you use zinc-chromate be careful it is a carcinogen (causes cancer) In the 1990's OSHA decided we needed to protect ourselves, so zinc-chromate is not sold over the counter. Only commerically. The car industry, chebby used it to spray the bird cage in the mid sixty corvettes. I think they used a spray can. It was hit and miss and didn't deter rust very well. Maybe the new replacment material is better. chuck
Old Dec 24, 2009 | 07:50 PM
52 Merc's Avatar
52 Merc
Originally Posted by bobj49f2
The more iron oxide on the vehicle the more the seller will think it's worth. Most time the price is about 80% of a completely restored vehicle.
Oh, Bob, you don't mean people like this...do you?
1951 OLD ANTIQUE FORD PICKUP Truck FOR PARTS #1:eBay Motors (item 160352865167 end time Dec-29-09 08:10:17 PST)
Old Dec 24, 2009 | 08:00 PM
mechmagcn's Avatar
mechmagcn
Originally Posted by 52 Merc
Must of been watching Barrett-Jackson just before posting that one
Old Dec 24, 2009 | 08:20 PM
rastiss's Avatar
rastiss
now guys, don't start over-using panel adhesives. 3-m 08115 is a great one, prolly my fav. i use it almost daily. i just put a door skin on an '08 camry rt. rear, and it only has 1 spot weld from the factory. the rest is all panel bond. for those scenarios it is a great option. however, on a section panel(lower cab corner, etc..), i NEVER use it on the area to be sectioned. it ABSOLUTELY WILL SHOW back up later. it will expand and contract and end up showing a line thru the filler. i don't care what ANY rep says. i have tried them all in my body shop. use zinc enrichened weld thru primers. under coating only helps a little. i really like kent automotives inner rust proofing liquid. use the wand for hard to reach areas. it spray out real watery, then turns to a wax type substance. kinda like a cosmolene. it's all that is really necessary.
http://www.kent-automotive.com/kent/main.nsf/resources/pdf/$File/N-71204_Kent%20Guard%20.pdf
Old Dec 24, 2009 | 08:21 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Check out that rear fender!
Old Dec 24, 2009 | 08:47 PM
Earl's Avatar
Earl
Wayne, I think that sale price includes the house in the background of one of the photos.
Old Dec 24, 2009 | 08:59 PM
Earl's Avatar
Earl
rastiss, that's a good access denial product and I think you are right on the money with your comments. Access denial products, at least in the aerospace industry, are designed to flow into ALL cracks and crevices down to 2.5 um (about 0.0001 inch) width. They then go through one of several "set up" stages during which they turn into a very flexible solid (like the waxy material you are using). The key thing is not so much their penetrating power (although that's important), but their properties after they set up. They have to remain elastic to temperatures closing in on -80F since they may see very low temperatures during high altitude flight. They are also tenacious adhesives and are pretty much non-removable without prolonged grit blasting. I tried to remove some from an Aluminum panel I got from the metal scrap bin at work and the grit was just bouncing off the compound for a long time. When I finally got it all off, the Aluminum was so messed up from all the grit blasting that I couldn't use it for the project I was working on. As far as chemical etches go, I don't know of any that will remove the stuff we used on aircraft wing fuel tanks without destroying the surrounding metal first.
Now if I could just bypass the CRS disease and come up with the name and manufacturer!?!
Old Dec 24, 2009 | 09:04 PM
BlueOvalRage's Avatar
BlueOvalRage
I've seen that listing several times. Apparently he's still trolling for his sucker. The first time I saw it, I thought that he must have added one too many zeroes, but after the 4th or 5th relisting, he must really mean it. Good luck to him!
Old Dec 25, 2009 | 12:26 AM
rastiss's Avatar
rastiss
earl/george, the waxy inner rustproofer cleans up easy with most solvents like paint thinner. now the panel bond/adhesive, you are right. it takes a grinder to knock it off. it is tuff stuff. to change a door skin, after you gring the flange off, it takes heat to release the adhesive. if you try to pry or chisel it apart, it makes for a lot of flange repair. the inner pannel spray is what I-CAR us requires to use on repairs that require corrosion protection. especially structural parts such as rails, aprons, etc....we have never had any kind of issue with it. it doesn't dry out like undercoat. like i say, i think it is a cosmolene derivative. a couple of other notes on panel bond. some are epoxy based, some are urethane based. urethane actually draws or takes on moisture. they require different prep than the epoxy or you create a rust magnet. i like the 3m 08115 the best. it also has glass beads in it to keep you from squeezing out too much glue. and once the panels make contact you CAN'T lift it back off or you have to clean the glue off and reapply. if dont, it will trap air in it leaving the bond compromised. just my .02.
Old Dec 25, 2009 | 02:01 PM
  #28
abe's Avatar
abe
If I am not mistaken that fender must have been homemade. Ford did not produce the spare tire fender until 1954. And those of you looking for a '53-'56 spare tire hanger, that is one right there that they used to mount the spare unto.... Quite the bargain!!
Also, isn't that a 48-54 Chevy truck hood in the back, I think it says Thriftmaster...
It says Best Offer, someone ought to offer him a small amount!
Old Dec 25, 2009 | 03:34 PM
  #29
49willard's Avatar
49willard
My personal favorite that I have done for years on vehicles is oil sprayed (with a syphon gun) in all areas. Two cycle oil atomizes the best. After painting spray oil into such areas such as cab corners, door bottoms and double panel reinforced areas such as at fender and running board mounting locations. Oily metal does not rust. Ever clean up a rusty vehicle that suffered a long time engine of trans rear oil seal leak? You can find original chassis black paint near the leak if the leak started early in vehicle life. I do it on my driver vehicles every fall. I live in Maine where we use plenty of salt on winter roads. It wil not totally stop rust in winter driven vehicles here but it will significantly slow it down. If I could readily get oil in every crevice I would be even more successful. On Willard after final paint but before assembly I will do things like position the fenders such that gravity will force the oil into each crevice. I will flood the areas and then let it drip/drain and wipe down any excess.
Old Dec 25, 2009 | 05:44 PM
  #30
52 Merc's Avatar
52 Merc
That is a beaut! Some people should have to obtain a license to buy a ball-peen hammer.
