ICM connection at distributor
Old Dec 23, 2009 | 03:42 PM
MTEPERA's Avatar
MTEPERA
i have an 84 Bronco with staright 6, manual trans
It dies after engine warms up, usually will run for about 30 minutes. I have isolated it to the 6 wire connector at the base of the distributor(i guess for the ICM). if engine is cold, i can start it and push this connector any direction, with force and there is no issue. Once the engine has warmed, if i barley push it forward the engine dies. I think this is my same issue that happens while driving, after engine warms. do not understand it, but pretty sure this is my problem.
How do i fix? do i have to replace the distributor?
Thanks, for the help. I have had the Bronco for 10 years and it has been very reliable.
Old Dec 23, 2009 | 04:56 PM
satkins1044's Avatar
satkins1044
replied in the other forum
Old Dec 23, 2009 | 10:59 PM
300 Buster's Avatar
300 Buster
Sounds to me like a broken wire.When the insulation on the wire is cold,it is stiff,keeping the broken ends connected and when it warms up,it's more pliable and lets the wire ends or connector ends separate.They could be broken inside the coating or at the end where they connect to the connector piece or even right at the module.It may be tough to find,but replacing your distributor probably won't do it.Replacing your module would take care of half of the wires and replacing the pick-up coil in the distributor would replace the other half.I think, it's been a few years since I ran that ignition,but I think that is the what you have.Disregard everything,I see on the other posts that you have the TFI type.When you replace the module on that one,be sure and use the special grease that comes with it,goes on the surface that contacts the distributor,as that is what keeps it from over heating.
Old Dec 23, 2009 | 11:08 PM
70sfordguy's Avatar
70sfordguy
I would replace the plug & shrink wrap the connections.
EWelsch
18
May 16, 2014 01:55 PM
74 F350 SCS
Oct 3, 2012 07:05 AM
mudder_lover
29
May 4, 2011 08:59 PM
mavrik4x4
15
Nov 23, 2009 03:31 PM
b4hntn
1978 - 1996 Big Bronco
Sep 16, 2007 09:53 AM
