Recurring ignition issues. Please help! Running out of ideas!
Apparently, I HAVE NOT remedied my issue.
Truck will die when idling to a stop WHILE THE ENGINE IS COLD.
Once it warms up, no problems.
I concluded that it is ignition related, as there is no sputter, stumble, anything of the sort...just straight DEAD. ASAP.
ALWAYS cranks right back.
Will idle all day.
No CEL or SES lights.
New plugs, dist cap and rotor, fuel filter, air filter, air filter.
All of the above was done and NO PROBLEMS for a week.
Rains today, and here we go again!
That only leaves 3 possibilities:
1.PIP sensor in the distributor.
2.Coil
3.ICM
I have BOUGHT an ICM, but I havnt installed it b/c after the fact Im reading all this 'gray ICM' vs. Black ICM and Im not following(translation if the gray that I purchased is problematic, I can take it back unused).
Will idle all day.
2.Coil
3.ICM
Evan a lot of the Ford dealers will still try sell you the wrong one, but a few of them are aware and will sell the right one.
At start up idle do the RPM's bob a bit like its trying not to stall at all or does it just always die? My 87 F-150 used to stall out, even when coasting to a stop, and start right back up when it was cold but when it warmed up no problems at all, ran fine. At first I thought it was cause I was REAL rusty with a clutch... Later I replaced the MAP sensor (after IAC, and TPS with no luck) and it never did it again.
SubFord, thank you for that information. I couldnt really find anything on the DIFFERENCE between the 2. Now it makes more sense! I will get on that later today.
Volvo, it idles fine. No dips, studders, anything. And if I let it sit out there until it reaches NORMAL OPERATING TEMP, it will never, not ONCE die on me. But the symptoms u are talking about sound about right.
Ok. Just found a BLACK ICM.
Installed and we shall see what happens...
Apparently, my fuel pump decided to take a dump on the front tank as my girlfriend was trying to crank the truck. All of a sudden it decided to not start(that is the 1st and only time it has done that).
BTW....I found the BLACK TFI by searching for an ICM for a 95 Mustang w/302.
That should help anyone else if they have the same issue...
