Having trouble bleeding M5R2 trans
Old Dec 23, 2009 | 01:07 PM
mdacton's Avatar
mdacton
Tried to blees the slave every way I know how. Power bleed it was well with no result.
If I do get a pedal on it when I start it up it goes away..... It def still has air in it I can feel it.
Removed trans to repair a shift fork and a front counter bearing and support. Now cant get iot bled. Have never had this problem before....or this much trouble
Old Dec 24, 2009 | 12:45 PM
EPNCSU2006's Avatar
EPNCSU2006
Open the bleeder with the pedal up, press the pedal to the floor, close bleeder, lift pedal back up. Repeat this until you get a good stream of fluid from the bleeder. Then pressure bleed like normal (pump pedal several times, hold to floor, crack bleeder, close bleeder, lift pedal, repeat). Also if the fluid ran out of the master cylinder, you might need to bench bleed the master cylinder before trying to bleed the system.
Old Dec 24, 2009 | 01:51 PM
MAS96F150's Avatar
MAS96F150
i used a big flat screwdriver through the inspection whole in te bellhousing and pumped the slave cylinder. works very well, it pushes the air up out of the master, which is the direction that it wants to go anyway so its alot easier than pressure bleeding cause that is trying to force the air down. just take the cap off the master and put a shop rag over it so it dosn't spray fluid everywhere. plus pumping the pedal repedily makes it worse to bleed, it breaks up any air bubble into many smaller ones dispersed throughout the line, making it harder to get them all out.
beersy50
Dec 6, 2015 12:41 PM
JimG1098
16
Apr 28, 2015 06:23 PM
azpowerstroke
Jul 9, 2009 10:08 PM
kilog55
30
Jul 6, 2009 08:34 PM
broncofixer
1978 - 1996 Big Bronco
Oct 31, 2004 02:51 PM
