vent window locks
Old Apr 1, 2000 | 01:53 AM
Jayson's Avatar
Jayson
vent window locks
Anyone know of a way to tighten up the vent window levers? It sounds like hurricane andrew when I'm going down the road. The vent window levers are loose and I need to tighten them. Anyone know how?
Jay
Old Apr 1, 2000 | 08:22 AM
Nitro's Avatar
Nitro
vent window locks
The easiest way I have found it to fold up some paper and put it between the latch and the little chrome plate where the latch rests. Ive seen wrist watches, coins, charge slips, Life Savers wrapers, and many other things to keep them from howling. Good luck
Nitro
Old Apr 1, 2000 | 03:51 PM
jbhf250's Avatar
jbhf250
vent window locks
Mine were `slightly loose` I nocked out the roll pin and found the pin slot was worn. I drilled out the pin hole on the handle and installed the next larger roll pin to tighten up the handle..
It took out about half of the `slop` in mine.
May work better for you....
__JOHN__Õ¿ö
72 F-250
ICQ#6030753
http://clubs.excite.com/comm/area/pw/welcome/main.asp?cid=188005&auth=
Old Apr 2, 2000 | 01:10 AM
BigBrownTruck's Avatar
BigBrownTruck
vent window locks
Most auto parts stores have a wingwindow lock. Don't rely on these for security however, last year I had a truck stolen and the means of entry was a prybar on the wingwindow. The lock was no match. It will work for synching down the window if your stock latch won't.
BBT
Old Apr 3, 2000 | 07:12 AM
frankie's Avatar
frankie
vent window locks
this must be a common problem. mine are loose too. i bought a roll of weather stripping, it comes in several sizes, and plan to put some in there to stop the wind.
i think it was poorly designed.
Old Apr 3, 2000 | 08:15 AM
jowilker's Avatar
jowilker
vent window locks
Jay, Carolina Classics has a list of parts from 48-77 for vent handles & brackets. They can be reached at 800-598-4211
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Apr 4, 2000 | 12:07 AM
jmg7184's Avatar
jmg7184
vent window locks
Both of my vent windows were tight, until some SOB broke into my truck throught the pass. side by prying on the vent window until he could slip something in and flip the catch. I had something wedged to take up the gap for a while, but I found the vent window locks like discussed earlier. They hold them tight, but the catch will still be loose.
Old Apr 4, 2000 | 01:36 PM
JMR's Avatar
JMR
vent window locks
mgargiullo
Sep 12, 2019 10:30 PM
bphirt1
16
Feb 17, 2016 08:54 PM
beartracks
Jul 24, 2015 08:24 PM
DirtyCustoms
13
Apr 21, 2012 07:36 AM
ALSAIR
1978 - 1996 Big Bronco
Sep 10, 2008 06:44 PM
