Seat Belts
Old 12-23-2009, 07:31 AM
cts1954's Avatar
cts1954
cts1954 is offline
Seat Belts
I am sure this question has been asked several times but I have had no luck with the search option. I have a 52 F1 and I am ready to put seat belts in. I am going with the 3 points belts and am looking for pictures of installing the shoulder harness bracket on the back of the cab between the door post and back window.
Thanks
Old 12-23-2009, 09:25 AM
Earl's Avatar
Earl
Earl is offline
I found this thread and it has a discussion of seat belts - but I didn't see any actual installation info.
www.ford-trucks.com/forums/598496-seat-belts.html
This vendor has some shoulder belt parts and probably can help you out with technical info on how they intended the shoulder belt to be attached to the cab.
Juliano's Hot Rod Parts & Interior Products - Custom Car & Street Rod Accessories
Someone else may be able to post some photos or install instructions.
Old 12-23-2009, 09:41 AM
mytbtruck's Avatar
mytbtruck
mytbtruck is offline
I rolled a piece of metal to the contour of the cab, welded a nut on it and welded it in place.
Old 12-23-2009, 09:43 AM
mytbtruck's Avatar
mytbtruck
The belts are comfortable when they are buckled.
Old 12-23-2009, 09:46 AM
jaye's Avatar
jaye
jaye is offline
I got mine from MidFifty however, you can get the same results doing what Larry did and pocket the difference.
Old 12-23-2009, 09:55 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,472 Likes on 1,411 Posts
Keep in mind that whatever you use for an anchor, if you ever needed to use it, there could be several thousand pounds of force pulling against it, depending on the impact and g-forces x body weight. Use a heavy gauge steel and weld it in place very well.
Old 12-23-2009, 03:24 PM
mytbtruck's Avatar
mytbtruck
I don't think you can overdo the strength of your installation. Heven forbid we never find out if ours are strong enough. I looked at the install kit from Julianos where I bought my belts and mine appears to be as srtong as the installed kit they have. Hope we never know.
Old 12-23-2009, 09:31 PM
carnut122's Avatar
carnut122
carnut122 is offline
I once read that OEM belt anchor positions have to be designed to hold the weight of the vehicle. OTOH, I'd say that's definitely better than not having any shoulder belt.
farmerchad
2004 - 2008 F150
01-20-2017 05:26 PM
DSE350
11-25-2016 09:29 AM
Kaslothedog
1999 to 2016 Super Duty
09-17-2016 05:59 PM
catskinner789
2004 - 2008 F150
01-26-2010 01:38 PM
hwyhogg
12-06-2009 10:15 AM
Quick Reply: Seat Belts
