Lost a glow plug tip....
Old Dec 22, 2009 | 08:47 PM
Fishin76's Avatar
Fishin76
But got it out today.
Here's how I did it.
I had my son put his finger on the gp hole to feel for the compression stroke and tell me when the air stopped coming out. You must be on the compression stroke, or a valve is open and the sucking effect will be less once you put a vacuum to the cylinder. I went in about 10-15 degree spurts so he could feel the air rush out. He told me when and I backed up about 5 degrees or so.
After I found TDC on the affected cylinder ( #7 for me) I used the tool in pic 1 to gently push the tip back down into the pre-cup just so it fell in. You could easily use something else (smaller diameter the better) that fit in the all the way to the bottom. After that, I removed the injector with a 1" deep well socket I got at O'rielly auto parts for $8.
Then I measured an cut the top portion of a transmission funnel off (not pretty) so that my shop vacs solid end went in and all but sealed to it. My 4.5 hp 12 gallon shop vac would hold the funnel to itself. I would recommend a bigger vac that this, as I will explain later.
Then I stuck this cheepy harbor freight blow gun in the GP hole. Let it bend when you put it in so you can get the tip as far down as you can. This one will go all the way.
Wiggle (yes, its a technical term) the blow gun around while you force the funnel attached to the shop vac in the injector hole until you cannot hear air coming in from the sides of the funnel.
Again, A bigger stronger shop vac may not need such a seal, but mine did. At one point after no success, I put the first tool in and kinda beat it about in the pre-cup at an attempt to free the tip from the carbon and diesel fuel mix ( i have a leaky injector), then went back to the blow gun and vacuum combo.
When it finally came out, I heard the tip rattling around in the end of the funnel. I pulled up quick, and pointed the funnel and vac hose to the pasenger side. Then it went all the way into the belly of the vac. yeah! A bigger vac may have sucked it all the way up and you would have only heard the tip rattle through the hose on its way to the vac dirt collector.
The recovered tip:
Hope this helps someone else
Old Dec 22, 2009 | 10:06 PM
Chevy 6.2D's Avatar
Chevy 6.2D
Good Work! A very creative idea
Old Dec 22, 2009 | 10:23 PM
Links56's Avatar
Links56
Nice Job! Good Thinking!
Old Dec 22, 2009 | 11:07 PM
Marianna2003's Avatar
Marianna2003
Hey Fishin76:
How did you manage to destroy the GP in the first place. What brand was it? Give PN or type also. Believe it or not the # of the plug matters. Glad to hear you received the GPs OK.
Old Dec 22, 2009 | 11:49 PM
Fishin76's Avatar
Fishin76
Well, believe it or not, It's a champion plug. I went to change all mine, and pulled out a smorgusboard of plugs. 2 beru's, 1 AC 8G, 1 autolite 1107, and a bosch 80024. I still have 3 plugs to pull. I stopped when #7 broke. All done by the PO's mechanic.
