ESOF?
Old Dec 22, 2009 | 08:46 PM
n2baja's Avatar
n2baja
ESOF?
What does this stand for?
Thanks,
Melanie
Old Dec 22, 2009 | 08:54 PM
maevans's Avatar
maevans
Electronic (or Electric) Shift-On-the-Fly (ESOF).
Old Dec 22, 2009 | 08:59 PM
Bigcat350's Avatar
Bigcat350
And they are nice when working properly.
Old Dec 22, 2009 | 09:21 PM
togobefastguy's Avatar
togobefastguy
is that even possible?
Old Dec 22, 2009 | 09:30 PM
Bigcat350's Avatar
Bigcat350
Mine are 10 years old and working like new. I set inside and turn the switch when I get in a jam and not having to get out and and lock it in is nice to me. Just do the maintenance on them as needed and it seems to be possible. I have done the maintenance that Guzzle suggest and it works so far
Old Dec 22, 2009 | 09:36 PM
n2baja's Avatar
n2baja
Thank you, maevans!
This brings up a new question:
I looked up the definition of "Shift-On-the-Fly" and got this: "The ability of a four-wheel-drive vehicle to be shifted between two- and four-wheel drive while the vehicle is in motion." Ok, that makes sense.
I have a 2001 F350 PSD 4X4 (automatic trans) with the switch on the dash for 4x4 hi and 4x4 low. The only other vehicles I've driven off-road are a '64 CJ3b and a '67 Bronco, both of which have manual transmissions with the second shifter for 4wd and the front hubs had to be locked in manually. So, basically, the switch on the dash of the 350 is like the second shifter in the 3b and the bronco, correct?
Old Dec 22, 2009 | 09:46 PM
mueckster's Avatar
mueckster
[QUOTE=n2baja;8271657]Thank you, maevans!
I have a 2001 F350 PSD 4X4 (automatic trans) with the switch on the dash for 4x4 hi and 4x4 low. The only other vehicles I've driven off-road are a '64 CJ3b and a '67 Bronco, both of which have manual transmissions with the second shifter for 4wd and the front hubs had to be locked in manually. So, basically, the switch on the dash of the 350 is like the second shifter in the 3b and the bronco, correct?[/QUOTE]
Yes, a transfer case lever and hub engager, too.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
