need parts scource(numberdummy)
Old Dec 22, 2009 | 06:37 PM
sgettin's Avatar
sgettin
hello. i need a couple seals for the front drive train on my truck(63 f250 4x4). i need the rubber and also the felt seals that are located up front on trunion arm(?), or in laymens terms the rubber and the felt seals that are on that round knuckle thing behind each front tire on a 4wd.
my mechanic hasn't come up with any at orielly's but he'll check around tomorrow. i am going to look at dennis carpenter also but if anyone (numberdummy?) knows where i can get something that will work i would appreciate the guidence.
thanks
scott
Old Dec 23, 2009 | 10:05 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Or in laymens terms the rubber and the felt seals that are on that round knuckle thing behind each front tire on a 4wd.
LOL...Almost everything you typed inre to these parts are layman's terms.
You do not want front wheel grease seals...
You want the large diameter seals that are on the inner side of the 3130 .. Spindle Arm (trunion arm aka round knuckle thing ).
I'm assuming these are the parts you need, cuz I don't see any other seals in this location.
These parts came in a kit. The same kit fits: 1961/76 F250 4WD's & 1977 F250 4WD's before serial # Y20,001.
2) D4TZ3132B .. Spindle Arm Seal Kit / D4TZ3132B replaced C1TZ3132A / Obsolete
D4TZ3132B =
WESLEY OBSOLETE PARTS in Liberty KY has ONE = 606-787-5293.
QUALITY FORD in Coushutta LA has ONE = 318-932-4063.
KLIMESH MOTOR SALES in Calmar IA has TWO = 563-562-3241.
JST AUTOMOTIVE in Lebanon TN has FOUR = 615-443-3086.
C1TZ3132A =
TISON MOTOR CO. in Estill SC has TWO = 803-625-2551.
No other Ford Dealer or obsolete parts vendor has either kit.
Old Dec 23, 2009 | 10:54 AM
sgettin's Avatar
sgettin
You want the large diameter seals that are on the inner side of the 3130 .. Spindle Arm (trunion arm aka round knuckle thing ). I'm assuming this is correct, cuz I don't see any other seals in this location.
D4TZ3132B =
C1TZ3132A =
i have to admit i was cringeing when i typed that one, figured i'd be lucky if anyone had a clue what i am talking about. but as always i think you've figured it out and i'll give the scources listed a call. i think these were the only parts i needed that weren't available at the local parts store.
thanks ND (i'll remember that- spindle arm term)
es2rider
Mar 24, 2024 09:01 PM
1986F150six
Nov 1, 2016 01:48 PM
Sheepdog48
18
Jun 7, 2013 05:52 AM
supercabfreak
17
Aug 28, 2011 10:18 AM
xsnowpig
Jun 26, 2007 05:25 PM
