I'm looking for ways to add power to my 94 torbo idi without spending too much (maybe $500-$600) and without hurting the longevity and fuel economy. Ive heard of a kit from ats that replaces some turbo parts, downpipe, ect. but I'm not sure where to get it or what exactly to get. any ways to improve my intake for more air flow??
You can start with a K&N replacement air filter element.
You can get the downpipe and I belive the housing direct from ats their website was junk the last time I looked but you can call them and get the info I understand.
ditch the lift pump and fan for electric.
this will free up some hp.i dunno,but id bet this is 15-25 hp increase alone.
ditch that extremely poorly designed stock Y pipe.
have a shop weld you up a Y pipe from the manifolds and join them evenly into a collector.
(the stock is such a joke.take a look at that passenger side and how it enters the drivers side pipe.its crazy!)
have them make it all 3.5 or 4". now,use a good quality free flowing muffler,and exit with the same 3.5 or 4" you began with.
i bet that alone is worth 20-30 hp!
the torque gains are probably more.
and mpg increase with these mods should climb drastically.
i also want to see about ditching the EGR valve,and stop re-burning that trash air for a bit more hp/mpg.
oh oops! lol.i was thinking "PVC valve" in our diesels its called the CDR. thanks.good catch.
it recirculates engine gasses back into the intake to be reburnt.
i was wondering if we could block this off,and or, let these hot waste gasses exit outside the engine,if it still needs to vent.
im thinking,we can block it off,drill a hole in a valve cover,and place an aftermarket crank vent so we dont have to reburn the crap lol.
I was one of them that tried to change the cdr set up. If you try to just vent it out it looks like the truck is on fire lol! I tried venting it into the exhaust and it just looked like I had bad rings. If it is working right it does its job and helps keep the air ***** off our old trucks. Here in northern kentucky peopel are really bitching about the guys that are rolling more smoke than a steam locomotive. I do have my pump up a little ( so it puts out some smoke under full throttle) but most of these guys are running new dodges and have them hopped up so that they roll coal almost at an idle.
I doubt seriously if the lift pump pulls a 1/2 horsepower and the fan if working right you can hold it with your hand until the temps reach 205,granted this only occurs when you are climbing a hill and need every horse.
LOL Dude, yea you don't want to become a pariah in your community. They'll pass a law and y'all will driving either a prius or a cube.
That nasty air is nasty with oil fumes that has more btu's than diesel so as it burns hotter it probably isn't hurting the performance.
Actually the opposite is true. On our IDI's. the CDR sits over cyl# 7 and 8. the oil fumes go in those cylinders and can cause too high of combustion temps in those cylinders. If you were to track gp failures, I bet you find a higher number of #7 and #8 failures.
