Sponsored by: Real Truck
Tire rotation question
Old Dec 22, 2009 | 08:22 AM
TheAdmiral's Avatar
TheAdmiral
I'm planning on rotating the tires on my newly acquired F250. The rear tires have roughly 40% tread remaining, evenly worn. The front tires have about 80% remaining and are evenly worn.
I'd like to get those rear tires up in the front quickly so that I can spread out the wear.
Any reason I would not want to do this ASAP? Is there a magic point at which you don't want worn tires up front?
Thanks
Old Dec 22, 2009 | 03:21 PM
bpounds's Avatar
bpounds
I don't think 40% is a problem up front. Problem is, as I'm sure you know, you've got so much difference between front and rear wear that you won't be able to catch up and even out. So you'll be replacing prematurely. If you're going to rotate, best do it ASAP as you are planning.
Alternatively, you could leave them where they are until the rears wear down a bit more, and then just buy two tires. Then adjust your rotation schedule to try to even them out before time to buy again. This is what I am doing because a previous owner let them get way out of sync.
Old Dec 22, 2009 | 03:57 PM
jim henderson's Avatar
jim henderson
Yeah rotate as soon as you can and keep an eye on them to see if you can even the wear.
Good Luck,
Jim Henderson
Summit 700
Crossovers
Jan 20, 2012 08:31 PM
Rrc
6.7L Power Stroke Diesel
Oct 5, 2011 07:26 PM
zecolleman
Oct 11, 2010 01:37 PM
///M Puller
Sep 20, 2008 12:10 PM
Snake1979
General Automotive Discussion
33
Jan 15, 2006 06:55 PM
