Problem with being in idle
Old Dec 22, 2009 | 07:04 AM
drewsbu's Avatar
drewsbu
Hi guys I just bought 2008 limited edition. I noticed that when the truck is idle the engine has a squeal sound coming from it. When I give it gas, the noise goes away. I also noticed it goes away when its warmed up. I do live in the northeast and its a bit cold (if that helps). What could it be?
Old Dec 22, 2009 | 04:46 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat
allternator change under warranty cured this known problem for me.
Old Dec 22, 2009 | 06:37 PM
fordtech08's Avatar
fordtech08
sounds like a belt tensioner or a fan clutch
Old Dec 24, 2009 | 11:53 PM
ford2go's Avatar
ford2go
Little late coming in on this, but you might try using a large screwdriver to locate the noise.
Obviously you have to be careful, but put the blade on a staionary part of something that you suspect, and put your ear on the handle. Watch for moving parts! I usually close my ear flap when I do this. (No good reason)
You will hear alternator noise for sure -- I never tried an idler
91dirtydiesel
13
Jan 24, 2011 01:00 PM
Swatter
Dec 4, 2009 06:24 AM
flcracker9
33
Sep 11, 2009 02:56 PM
Melchiah
Exhaust Systems
Jan 18, 2008 01:03 PM
