Engine block heater cord
Old Dec 21, 2009 | 06:33 PM
officer131's Avatar
officer131
Question Engine block heater cord
Out of all the times and days for it to happen. This must have been one of those things were it was just breaking down over time.
Today the three prong plug for the engine block heater cord broke. Couple of questions are:
1. It broke right at the tip of the three prongs. Should I just strip the three wires a little bit and hook up a new end?
2. Should I just replace the entire cord?
3. If I replace the entire cord, where does the cord actually end up hoking to the engine?
I tried to look, but it disappeared somewhere behind the driver side bumper/frame area. I didnt have all that much time to investigate.
Thanks in advance.
Al
Old Dec 21, 2009 | 06:37 PM
swaybar's Avatar
swaybar
no biggie at all..... just cut the cord right at the plug and go to homedepot an get an all weather outside plug. i replaced mine last winter and i'm not 100% but i think its just three wires that need to be tied in.....
Old Dec 21, 2009 | 06:42 PM
maevans's Avatar
maevans
Simply fix, just install a new cord end.
Old Dec 21, 2009 | 06:55 PM
maevans's Avatar
maevans
Anwser to #3 - Right above your oil filter.
Old Dec 21, 2009 | 08:54 PM
itsjustdan26's Avatar
itsjustdan26
For the wiring challanged..... Can someone pull up a diagram or something to show where each wire would go on the plug? Also if you could find a SKU or something for a certian plug to use? That way I can save myself 20 bux and not have to pay a friend to do it lol. Thanks!
Old Dec 21, 2009 | 09:33 PM
officer131's Avatar
officer131
Thanks guys. I think the depot is the way to go. Stopping on thew way home from work in the morning.
I think there should only be three wires. Hopefully they are color coded from the factory hook up.
Al
Old Dec 21, 2009 | 09:46 PM
BioHazrdMan's Avatar
BioHazrdMan
The cord end (cap, plug) that you buy from Home depot SHOULD have a gold, silver, and green screws that you land the wires under.
Gold screw is your hot (Black wire)
Silver screw is the neutral (White wire)
Green screw is your ground (Green wire)
That is assuming that is the colors of wire coming from the truck cord. Maybe that will help!
Old Dec 22, 2009 | 03:48 AM
officer131's Avatar
officer131
Thanks all,
The cord from the truck is wrapped all in black now. I will have to stripe the cord and see if they are colored underneath.
Old Dec 22, 2009 | 06:15 AM
Trouble1263's Avatar
Trouble1263
I just did a heater cord mod and if I remember, the factory cord is a 3 wire in a flat arrangement.the middle conductor should be the ground..For the other wires ,I cut one at a time and tested continuity across the snipped plug end and hooked up accordingly.The wider spade of the plug is the neutral and the narrow spade is the "hot".You do want to keep the polarity straight.
Old Dec 22, 2009 | 08:28 AM
DieselCamper01's Avatar
DieselCamper01
If you look really closely at the cord it tells you which is the neutral. The middle wire is green. Follow Duanes instructions above and you will be good.
Old Dec 22, 2009 | 09:24 AM
Izzy351's Avatar
Izzy351
It's a resistor. Technically, it doesn't matter which side is hot or neutral. But do it right. Small spade (if you buy a polarized plug) is hot (black), large spade is neutral (white), and ground is obviously the round one at the bottom (green or no insulator). Never been into the cord, but I would hope it has the standard colors in there.
Old Dec 22, 2009 | 10:38 AM
farmdad's Avatar
farmdad
This is Jim's area of expertise. Wish he would pop on once in a while.
Old Dec 22, 2009 | 10:39 AM
eodmule's Avatar
eodmule
Years ago my cord shorted out from rubbing on the front bumper. If I remember right the colors should match, ie white to white, green to green, etc. You could always get a multi-meter (or borrow) and as you look at the plug, match each wire one at a time on the new plug. Don't forget to make it water tight when you are done.
I installed a Marinco plug in the bumper. You just drill a hole in the bumper and mount it in the hole. Very cool. I'll link some pics when I get home tonight.
Old Dec 22, 2009 | 11:20 AM
Ponyboychris's Avatar
Ponyboychris
This is a mod that slipped my mind until now. Love to see how you did it and possibly where you purchased the Marinco plug.
Old Dec 22, 2009 | 12:40 PM
maevans's Avatar
maevans
Here is where I mounted mine Chris.and you can buy them at BassPro Shop. - http://www.basspro.com/webapp/wcs/st...SELL_THUMBNAIL
This is where I bought mine. - http://www.boatersworld.com/product/...ttery-chargers
Or you can take your pick - http://www.google.com/products?sourc...ed=0CCoQrQQwAg
