Interior Leak Stilll Not Fixed!!!!!
Old Dec 21, 2009 | 01:23 AM
builtfordtough13's Avatar
builtfordtough13
So my aunt took her truck into the dealer just before the warranty was up to get the interior leak fixed, it turned out it had two, one from the front and one from the rear sliding window. The dealer said it was fixed and then two weeks later and just over the 3 yr 36k warranty there was a big rain storm first one since they got there truck back. They noticed it was still leaking, will it be covered since it wasnt repaired the first time or will they have to pay out of pocket? Thanks
Old Dec 21, 2009 | 01:58 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
check the 3rd (rear) brake light.
it's a well known issue on the 04-06 trucks...and occasionally on the 07-08 trucks
you can fix it for about $3-10 yourself. get some of that DIY Gasket material from your local parts store...or just a good RTV.
Remove the 3rd brakelight and replace the gasket. Either way works...just whichever floats your boat
Old Dec 21, 2009 | 10:20 AM
builtfordtough13
Thanks, they have replaced the third brake light, after she backed into the garage door and cracked it. They are gonna go talk to the dealer today or tomorow and see if they will cover it, and then go from there.
Old Dec 22, 2009 | 01:21 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
There should be more than 2weeks warranty on work done at the dealer they should be fixing it till they stop the leaks fore good and not charge you for it.
1979Mustang
Apr 30, 2012 03:44 PM
saltamontes
Mar 5, 2012 11:44 AM
GCLL
6.7L Power Stroke Diesel
79
Dec 5, 2011 08:33 PM
Jlckb5
2004 - 2008 F150
Sep 6, 2011 08:47 PM
shizzu
Dec 2, 2010 09:52 AM
