gauge install
Old Dec 21, 2009 | 10:00 AM
big poppa's Avatar
big poppa
I lent out my detailed Dieselmanor directions to a FTE brother Adam0331 during the summer and he put his in, they are right on, great directions, even a cave man can do it..I could get some copies of those directions and send them to yaa if you wanted to give it a shot, plug and play basically.
Old Dec 21, 2009 | 08:52 PM
proudtruck's Avatar
proudtruck
I already have my gauges they are the auto meter cobalt gauges just to say I called a local shop in San Antonio and they want 300 to install them that's crazy since I have the gauges already
Old Dec 21, 2009 | 09:14 PM
big poppa's Avatar
big poppa
Don't know what else to tell yaa, for the most part we all try to do our own work on our trucks, at least what we can handle. Keep getting quotes and good luck finding somebody that will do it for a decent price.
Old Dec 21, 2009 | 09:38 PM
officer131's Avatar
officer131
I also have the cobalt gauges. I purchased from www.itpdiesel.com look at that website and go to instruction section and there is a detailed with pics. no biggie.
$300 dollars is outragous.
here are the directions that were given to me. http://www.itpdiesel.com/other/7.3L%...structions.pdf.
its actually in the documentaion section and look for the pre assembled gauage pillar.
Old Dec 22, 2009 | 12:22 PM
robinsonpowerstroke's Avatar
robinsonpowerstroke
Did you ask them if that is dry or lubed? LOL Sounds like it is dry to me!
Old Dec 22, 2009 | 01:52 PM
Izzy351's Avatar
Izzy351
Too bad SA wasn't a bit closer... It really isn't that hard, man. If you can read & follow the directions, you can't go wrong. The only thing I suggest is that you find someone that has experience tapping. It's not difficult, but easy to screw up if you haven't done it. You could also try practicing on some scrap metal, preferably something similar to the exhaust manifolds or up-pipes. That should get you enough practice to get 'er done!
Old Dec 22, 2009 | 05:42 PM
gasgrunt88's Avatar
gasgrunt88
I am a bloody idiot when it comes to electrical. (I'm learning though.) I did the install myself and it really is simple. If you can strip a wire and crimp on a connector or what have you then it's a piece of cake. Go for it! Gotta learn somehow, thats been my approach with most things on my rig and I'm much more knowledgeable now.
Old Dec 23, 2009 | 11:21 AM
proudtruck's Avatar
proudtruck
man me and my friend installed the gauges and everything I thought was going well but then I think he drilled the probe hole in the wrong spot it was suppose to be before the exhaust manifold but he drilled on exhaust manifold and my gauge is the cobalt 6144 gauge with a clamp on probe an it doesnet seem to be working my thing is does it matter where the hole is drilled or would it be the gauge might be defective
Old Dec 23, 2009 | 06:57 PM
gasgrunt88's Avatar
gasgrunt88
If it's the clamp on EGT probe, it should be going in the exhaust up pipe. That's where mine is and no problems out of it yet.
Old Dec 23, 2009 | 09:03 PM
big poppa's Avatar
big poppa
There's two places you can tap, the up-pipes going to the turbo or in the DS manifold, like I did, mines identical to this pic click here. 3-Gauge Install Pictures..did you drill here http://www.dieselmanor.com/diy/PSD3-gauge/image27-1.htm
Old Dec 23, 2009 | 09:46 PM
proudtruck's Avatar
proudtruck
yes my buddy did drill there but only thing is the gauge is a clamp on type
Old Dec 23, 2009 | 10:07 PM
gasgrunt88's Avatar
gasgrunt88
I would think that you can still just tap the manifold and put a plug in there. Just move the probe over to the up pipe. Anybody else have another idea?
Old Dec 23, 2009 | 10:21 PM
  #28
big poppa's Avatar
big poppa
I'm sure you could tap it with the ntp tap and bolt it up so to speak Chris. To proudtruck, I gotta ask, where were you when you buddy was drilling that hole? Unless you just put the probe in that hole, you'll need to thread it.
Old Dec 24, 2009 | 02:47 AM
  #29
gasgrunt88's Avatar
gasgrunt88
Proudtruck, you might consider contacting Autometer and find out if you can use the probe fitting from another gauge series. I would imagine most if not all of their pyrometers use the same probe so you can probably just get the fitting and stick that sucker right there in the manifold.
Old Dec 26, 2009 | 08:07 PM
  #30
proudtruck's Avatar
proudtruck
can anyone post some pictures of the way the clamp on egt gauge should go on
