Glow Plugs
Old Dec 20, 2009 | 06:56 PM
jamesmcowan's Avatar
jamesmcowan
Glow Plugs
I know I have seen several posts on glow plug replacement. I see how to do this but what I am looking for is what else to do while I'm in there under the valve cover. Seems like there was something to do with shimming the harness on the injectors and maybe checking the head bolts. Thanks
Old Dec 20, 2009 | 08:43 PM
crazymut's Avatar
crazymut
Torquing your injectors was hte main one. Check your wire harness also. Yhe glow plugs are a piece of cake.
Old Dec 20, 2009 | 09:40 PM
PaysonPSD's Avatar
PaysonPSD
While under VCs
Check torque of inj. hold downs and rocker pedestal bolts.
UVCH retainers LINK or UVCH quarter mod LINK
Tip for removing GPs. Once they are broke loose put a piece of tight fitting tubing
over the end to aid in unthreading. Same-same to install new GPs.
Old Dec 21, 2009 | 08:30 PM
jamesmcowan
This is one great site for 7.3 owners.
Old Dec 21, 2009 | 09:26 PM
mueckster's Avatar
mueckster
Stick around here and you just might learn something. I know I have. If you don't, you're not paying attention. lol
The main thing I have learned here is that you couldn't ask for a better groups of guys and gals to have your back. "You've got problems, we got answers."
Old Dec 21, 2009 | 11:01 PM
crazymut's Avatar
crazymut
You can say that again!
Old Dec 22, 2009 | 09:10 PM
Dirtrider0213's Avatar
Dirtrider0213
Question
Whats the best brand of glow plugs to go with?
Old Dec 22, 2009 | 09:15 PM
togobefastguy's Avatar
togobefastguy
if i am not mistaken motocraft.
Old Dec 22, 2009 | 09:25 PM
schlepprock250's Avatar
schlepprock250
Originally Posted by PaysonPSD
While under VCs
Hey guys,isn't it supposed to be "inch pounds",not "foot pounds"?
onelionhunter's Avatar
onelionhunter
Motorcraft
get the motorcraft, do NOT get autolites.....
Old Dec 22, 2009 | 10:05 PM
jackstraw's Avatar
jackstraw
I'll say it again then. This is one great site for 7.3 owners.
It will be a long time before I am messing around under the valve covers, myself, but I know where I will look when I am ready!
Old Dec 23, 2009 | 08:28 AM
PaysonPSD's Avatar
PaysonPSD
10 ft/lbs = 120 in/lbs
Old Dec 23, 2009 | 08:47 AM
rat49f6's Avatar
rat49f6
Clay sells the motorcraft glow plugs, we discussing them last night. I plan on doing all of mine this spring
Old Dec 23, 2009 | 08:53 AM
Ponyboychris's Avatar
Ponyboychris
Not a bad job removing the valve covers. I helped a fellow FTE'er a few weeks back with this job, neither one of us had ever done it before and we replaced all 8 GP's and torqued down everything in under three hours. The hardest part is getting everything out of the way of the VC's and not having the right sized tubing made it a bit difficult.
Use Motorcraft GP's only! ZD-11's is I think the ID number. F4TZ12A342BA is the part #.
Old Dec 23, 2009 | 10:13 AM
schlepprock250
Thanks..
