I have 2004 Expedition that the drivers side passenger power door lock is not working. I can not even pull the *** up to unlock to get door open to take the panel off.
If the lock slipped down under the panel (inside the hole). Take a paper clip straighten it out and make a little hook on the end to see if you can worm it over to the hole,to pop the door open.
Not sure if this is the issue,but worth a shot if it is.
I have found that removing the seat does not help. As the screws to the door panel go below the door jam. So I can not get to them unless the door is open.
I'm not sure about your 04 but my 99 has a child safety switch on the door by the latch, of course the door has to be open to access it which isn't much help to you right now, but I wonder if that didn't get bumped causing your problem, if yours has it that is. Any way what I would suggest is grabbing the **** with a pair of pliers and jiggling it up and down and see if it'll eventually work itself free.
Plenty of *** to hold on too. It just wont pull up.
I am thinking that something came off inside.
I can here something try move when I use the remote unlock.
