Looking Bad *** Keith. I scratched mine up like crazy because I was too anxious to wait for a helping hand sometimes. Take your time, and use plenty of padding.
Just lurking in this section and ran across this thread and WOW! This is a magazine cover truck if I ever saw one.
As for the question on assembly, use 3M automotive tape on all edges that you will be attaching parts. I prefer the 2" just for more coverage. The 3M tape will not pull the paint or leave any sticky when you pull it off.
Look forward to seeing the truck in the magazines soon.
I used a lot of poster paper to cover a larger area. It is cheap and you can easily cut out contours to cover parts. Like the man said use only 3M tape. Good luck and you truck looks very good.
Try hard to take your time, you certainly don't want to scratch that baby. It's going to look good on the front cover of the lineup of magizines that will want you. Congratulations Keith.
The best proportioned stretched cab I've seen to date.
Some tips: You can use the plastic from old milk jugs to make a protector shaped much like a wrench which will allow you to tighten bolts/nuts with a socket/wrench without scratching the paint. Another is to use the pressure sensitive tape (like what is used to transfer vinyl decals to metal) to protect the surfaces. I've seen it in 2 & 3 foot wide widths which will allow you to cover entire fenders, hoods etc. It will not harm properly applied and cured paint when removed. I believe 3M makes it.
http://www.shop3m.com/70006444395.html
try ths link. Not sure if this is the same as we use in my aerospace application but same princeable. Cut off large sections and cover entire fender, door etc.
Reason: add web link
