1995 7.3
Old Dec 19, 2009 | 05:00 PM
fordfinatic's Avatar
fordfinatic
This truck is still having shifting problems. and its still throwin a VSS Code a code PO500. Any ways of testing a PSOM or is this a possibility of going bad?
Old Dec 19, 2009 | 05:25 PM
95_Dually's Avatar
95_Dually
I am not sure of the VSS code, but I am wondering if it is related to the RABS Rear antil lock brake sensor. I know it controls a couple of different systems, ie: cc, speedometer etc. I would try removing it and cleaning the sensor. It is worth a try.
Old Dec 20, 2009 | 11:32 AM
plowhand's Avatar
plowhand
Playing in the Dirt
Pull the VSS out of the dif. and clean all of the gunk off of it and see if that clears it up.
Old Dec 20, 2009 | 07:40 PM
fordfinatic
i have replaced the sensor in the rear gear twice already
Old Dec 20, 2009 | 10:33 PM
95_Dually's Avatar
95_Dually
So that is the same sensor? I wasn't sure. Check the wiring to see if you see any breaks.
Old Dec 21, 2009 | 10:41 AM
strokin'_tatsch's Avatar
strokin'_tatsch
Sam, just to clarify. the VSS is in the housing of the rear end and the RABS is on the driver side frame rail by the tranny. you will see the brake lines going to it. was that your question about the same sensor???
Old Dec 21, 2009 | 11:28 AM
95_Dually's Avatar
95_Dually
Yes. I have not had any problems with either one so I have not touched either one. I thought that they were one in the same. Thank you for clearing that up for me.
Old Dec 21, 2009 | 04:02 PM
madpogue's Avatar
madpogue
They are. There's no sensor in the breakout box on the frame rail. It's the "output" of the ABS, the place where brake hydraulic pressure is adjusted front-to-rear. The sensor (the "input") is indeed the one in the (rear) diff. It's been said, here and elsewhere, that the part is typically listed as a RABS sensor, and if you go in asking for a VSS, you'll get the wrong part.
Old Dec 21, 2009 | 06:03 PM
fordfinatic
Ive checked the wiring and it looks pretty good. So if this was yals truck what would yall do next and what could be failing. and what could i test?
Thanks
Old Dec 22, 2009 | 12:06 AM
95_Dually's Avatar
95_Dually
Is it possible that the part that the RABS picks up is loose or missing? I am not sure what it looks like in the rearend but maybe the problem is in there.
Old Dec 22, 2009 | 02:12 AM
joe_13894's Avatar
joe_13894
There is a tone ring that bolts onto the carrier with the ring gear. I guess it could be crapped up enough to cause a problem.
