newbie
Old Dec 20, 2009 | 06:13 PM
bull.rider's Avatar
bull.rider
i do all my oil changes at 4 or 5k and ony burn good fuel i would delete egr i think as my trucks do a lot of idle time what about chips?
Old Dec 20, 2009 | 06:14 PM
bull.rider's Avatar
bull.rider
how hard is it to pull the heds on a 6.0
Old Dec 20, 2009 | 06:19 PM
patrickke's Avatar
patrickke
cab=off!!!
Old Dec 20, 2009 | 06:20 PM
cheezit's Avatar
cheezit
chips... go to custome tunes by eric or t,wildman or some other know person they will improve the odds at reducing others. also SCT is a good route to take there.
How hard are heads to pull? well this goes back to not hard for me but I have never met you and there for can not make a resonable determaintion of your abilities.
I can get a set done in 12-15 hours on a bone stock truck. longer if lifted and modded. thats not counting any type of diag thats just spinning bolts
Old Dec 20, 2009 | 06:21 PM
gearloose1's Avatar
gearloose1
cheezit...
What do you consider "trash fuel"?
Old Dec 20, 2009 | 08:20 PM
bull.rider's Avatar
bull.rider
well lets not forget the ford driveline has had a 85 4 door short box body put on it so might have a bit more room to get the heads off??
i have done several head gasket jobs but never on a diesel oter then a 01 24v cummins pretty basic
what is the reason for romving cab but does it give acces to?
Old Dec 20, 2009 | 08:39 PM
patrickke's Avatar
patrickke
Some people can do it without removing the cab, but the easiest way to get to them is removing the cab because its so crammed and its "kindof" a cab forward design
Old Dec 20, 2009 | 09:23 PM
cheezit's Avatar
cheezit
trash fuel for me well. We get a lot of trucks with delaminated tanks, excessive water in fuel, old fuel that has been poorly stored. Theres a few of us at the shop that drive diesels so we filter and mix till we get enugh to run. we pump out 100-200 gallons a week worth and split it up. Its cheeper for us, cheeper for the shop as well. reduce, reuse and recycle ya know. So i have to do a little work for it but in the end its worth it.
Old Dec 20, 2009 | 09:38 PM
zhilton's Avatar
zhilton
Originally Posted by bull.rider
lol yea ford just sues there engine buider haha
They're both to blame for the problems & reputation the 6.0L got. Ford from KTP was running the 6.0L/VT365 hotter & harder than Navistar was doing in larger chassis trucks. Navistar knew Ford was running 'em that hot and continued to use TTY bolts instead of proven studs that were made with harder material...to save expense at Indianapolis (the only reason I can come up with). That's alright Ford & Navistar...I know the solutions to fix the few short coming of my PSD. The EPA is also to blame for some of the problems (EGR)...and Cummins has been having some issues in that department. Last truck I drove was an ISX powered 9400 and it burned up two different EGR valves within 30k miles (and that's all highway mileage); the dealership told me it was an accepted failure, and they carried 2 dozen in stock in the parts department.
what kinda milage shoud i expect from a sex liter (6.0)
what are known problems with an 03?
Running light and under 70mph I get 19-20 mpg. The heavier the trailer & faster/harder I run the truck the lower the mileage goes. But the power never drops off. I've passed several Dodge/Cummins on the interstate pulling what looked like equal sized loads. And it feels good to know that the front end and tranny aren't going to fall out of my truck before I get to 100k miles.
Old Dec 21, 2009 | 06:23 PM
bull.rider's Avatar
bull.rider
i can honestly say this is the second front end in my 95 dodge EVER original clutch motor has NEVER been touched hauls 10,000+ lbs every weekend and the truck has 431056km on it so cant cut up the ole cummins to fast
How hard is it to delete my egr as where i live no etest required
truck has 5 inch turbo back custom exhaust should help turbo from f***ing up
its an 03 chassis with only 86,000km should be pretty decent all dealer maintained
Old Dec 21, 2009 | 06:41 PM
cheezit's Avatar
cheezit
its the new cummins Im tearing up. apples to apples.
Old Dec 23, 2009 | 11:35 AM
bull.rider's Avatar
bull.rider
what is the most recomended chip for a almost stock 03 6.0L and should i delete the egr?
it has cold air intake and 5 inch
Old Dec 23, 2009 | 05:25 PM
  #28
patrickke's Avatar
patrickke
sct or spartan...I would delete the egr I haven't but when I get enough $$$ I will
Old Dec 23, 2009 | 08:38 PM
  #29
bull.rider's Avatar
bull.rider
any one know what the edge platinums are like on the 6.0 stock?
Old Dec 23, 2009 | 08:42 PM
  #30
gearloose1's Avatar
gearloose1
Your stuff beats the heck out of most bio-diesel!
Merry Christmas.
