wiper delay not working
Old Dec 18, 2009 | 06:58 PM
ol74hb's Avatar
ol74hb
I just did the conversion on my 79f250 the wipers work on high and low and when put to delay it is just like it is on low no delay? the part number is 17c476 the box what gives?
Old Dec 18, 2009 | 09:40 PM
fordtech08's Avatar
fordtech08
did you hook your grond wire up to a good ground?
Old Dec 19, 2009 | 08:29 PM
ol74hb's Avatar
ol74hb
worked on it today I ran a ground from the neg. on the battery just to be sure there is a good ground and still the delays don't work. everything else works hi/low and the washer pump. any ideas or did I just get a bum unit?
Old Dec 19, 2009 | 08:39 PM
fordtech08's Avatar
fordtech08
there is a good chance you have a bad govenor you might be able to pick that up at auto zone, don't think or it as you got a bum unit think of it as you got a working switch
Old Dec 19, 2009 | 09:53 PM
ol74hb's Avatar
ol74hb
where and what would the govenor look like and be? thanks, this sucks I wanted to get them working for the storm tonight they would be great while driving in the snow plowing.
Old Dec 19, 2009 | 09:56 PM
fordtech08's Avatar
fordtech08
it's that little box that goes inline with your harness maybe 2x1x1 inches it goes switch box wiring harness
Old Dec 19, 2009 | 10:01 PM
fordtech08's Avatar
fordtech08
if you follow the link this is what box I'm talking about
68 69 70 71 72 73 74-91 Ford Truck Delay Wiper Switch:eBay Motors (item 180438862038 end time Dec-28-09 16:38:30 PST)
Old Dec 19, 2009 | 10:42 PM
ol74hb's Avatar
ol74hb
ok thanks I did not know that the box was called a govoner. guess I got to get one more and hope it works.
Old Dec 20, 2009 | 06:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What vehicle did the 17C476 .. Windsheild Wiper Governor come from?
You only typed the basic ID number of 17C476, what is its prefix and suffix? There's no way to tell which one it is, without that full ID number.
Example: Ford ID number: D8TF-17C476-AA = Ford part number: D8TZ17C476A .. Windshield Wiper Governor / Fits: 1978/79 F100/350 & Bronco.
There are...at least TWENTY different types of these used on 1970/80's car/trucks.
If you type the entire ID number, I can tell you what else it was used on, maybe find you a new one if the one you used is obsolete.
Old Dec 20, 2009 | 11:48 AM
ol74hb's Avatar
ol74hb
the numbers on the black box just has 17c476 there is a white ford paper tag on the wires that reads E9TF-AA and under that the next line is 14A642 that is all the numbers I can find on it
Old Dec 20, 2009 | 12:55 PM
1977f250's Avatar
1977f250
Where did you get your switch and black box from? Know what it came out of?
Old Dec 20, 2009 | 01:01 PM
mblayton's Avatar
mblayton
More than likely its the governor, had the same thing happen on my Bronco.
Old Dec 20, 2009 | 02:34 PM
ol74hb's Avatar
ol74hb
got it off ebay so who knows what it came out of and if it worked before.
Old Dec 20, 2009 | 03:56 PM
Tees77f150's Avatar
Tees77f150
I was looking at mine and it reads
7Z2 260 7L03
E7F17C476- AB
DO NOT DROP
Then on the harnes there is a sticker wrapped aroud it that reads Ford E7, looks like 1T then under that is 14A642BB under that is N00302, lastly under that is 7-H.
Mine is a flEbay deal to, and the guy does not live that far away, I could knock on his door if needed, but he assured me it works just as it should.
Old Dec 21, 2009 | 08:03 AM
Tees77f150's Avatar
Tees77f150
Back to the top, to see if these numbers mean anything!!
