coolent temp problem
Old Dec 18, 2009 | 12:29 PM
Ottneys250's Avatar
Ottneys250
Hey guys I had the cold starts in ohio form...and Trying to get my 302 it get more consitit starts in the winter/cold. Well I put my coolent temp sensor in and it cranked over about 8 times ,and now is not even cranking over any more.
Any ideas what it could be ?
I checked all the wires coil
Old Dec 18, 2009 | 01:38 PM
Conanski's Avatar
Conanski
If the motor doesn't crank the battery is probably dead so put it on charge.
Old Dec 18, 2009 | 03:50 PM
Ottneys250's Avatar
Ottneys250
I tryed jumping it do...nothing. Do you think it needs to be put on the charger...The battery gauge is going in the middle when I turn the key over
Old Dec 19, 2009 | 12:59 AM
Beanscoot's Avatar
Beanscoot
Well it could also be that the jumper cables weren't making good connection, or your starter/solenoid is faulty, or your ignition switch is faulty, or there are bad connections in your cranking circuit (the heavy cables going from the battery to the starter motor and engine block.
"I checked all the wires coil"
I assume you mean the spark plug (high tension) wires. These won't affect the cranking of the engine, even if they're missing!
