Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Legal load limits
Old Dec 19, 2009 | 10:29 AM
Snowking's Avatar
Snowking
hmmm good to know I should really double check what Im insured for then. lol Who knows if United Rentals cheaped out for cheaper insurance
Old Dec 19, 2009 | 10:31 AM
preppypyro's Avatar
preppypyro
With a company like that, I doubt it, but hey ya never know!
I just know for myself I didnt need to pay for more then I actually towed.
Old Dec 19, 2009 | 05:38 PM
Diesel Fiend's Avatar
Diesel Fiend
To the earlier threads, GVWR also take in to consideration the ability to stop safely. Anyone can take an F250 and throw bags and a bigger spring pack in there to increase your hauling capacity, but if you can't stop you will likely kill someone. Larger trucks have better brake packages. Additional axles on trailers add more braking wheels along with each axle. Overloading your truck and hard braking will lend itself to a phenomenon called Brake Fading. Snowking can correct me here, but I think it comes from the brakes heating up to a point where the surface of the brake pads become slick and don't grab the drum. That much heat can also throw your drums out of round so you have even less braking power. This is why larger trailers have electric brakes and more axles.
Old Dec 19, 2009 | 09:57 PM
Snowking's Avatar
Snowking
That is pretty correct about brake fade, and a very good point. I assume though Ford took that into consideration when listing the GVW of a truck (at least I hope) Pads will become slick and wear away rapidly (literally burning off) with brake fade, the drum expands and cracks, then the **** hits the fan
On a side note I know Fullcrew has added a aftermarket Jake brake to his truck which helps alot, when using my Engine brake in my fullsize semi I rarely use my foot brake anymore.
Old Dec 20, 2009 | 08:19 AM
Fullcrew7.3's Avatar
Fullcrew7.3
Ryan, I used an LT9000 for my road test. Unfortunately, they sent me with a really short tandem axle flatbed, so that backing part was a bit tougher. I had hoped for the tridem end dump. So much easier to back. Yup, I did the walkaround. Scary part about that, is the lady doing the examining had been a travelling dental hygienist that came to the area schools when I was in Elementary school. She'd never even moved a semi, let alone driven one. Everything straight from the book
Old Dec 20, 2009 | 08:24 AM
Fullcrew7.3
As for the braking, yeah, that designed into the vehicle based on the desired GVW the manufacturer is going for.
About the exhaust brake, I love it. May just be the best $7 I spent on mods. On the 7.3's the exhaust back pressure valve can be converted into an exhaust brake by wiring in a switch and a separate 112v powers source. Works best at higher RPM. Not quite as good as an aftermarket one, but still gets the job done and VERY little cost.
Old Dec 21, 2009 | 09:21 PM
preppypyro's Avatar
preppypyro
An exhaust brake on a semi is about the most useful thing ever.
If I did alot of towing I would install one in a second on my pickup truck.
Regarding the break fading, when I lived in BC I heard lots of stories about guys riding their brakes coming down the Coq, and having to get a complete brake job in Hope!
Also with larger trailers you can overload a set of axles and get a fine, and not have your whole truck overloaded. (not sure if that was mentioned or not)
1981fordstepside
13
Jun 24, 2014 06:13 PM
eldorado73
Sep 2, 2011 10:13 PM
fp_5
18
May 25, 2009 09:38 AM
datsun_1600
Jan 3, 2008 04:46 PM
Frisco the Dog
Apr 26, 2006 09:25 PM
