460 Ideas, Suggestions, Information, Needed
I am looking for ideas / suggestions for a fresh engine. I am past the point where I need most, if not all, the horsepower available. A smooth running, reasonably economical, dependable engine is what I am after and all that I need.
Not really interested in converting to EFI, but I wouldn't rule it out. Just not my first choice.
Not opposed to changing to a 429 or even back to a 400.
Here are my minimum parameters.
Able to run on pump gas.
Smooth idle at 650 rpm.
Reasonable economy.
Decent power. I occasionaly (6-8 times a year) tow a loaded tandem axle trailer with a gross weight of 7,500 pounds.
Any suggestions would be appreciated. If you can include specifics, such as pistons, heads, cam, ignition, intake and carb, that would be great.
Thanks,
Roger Carter
