460 starting problem..
Old Dec 17, 2009 | 04:24 PM
richardfine's Avatar
richardfine
I have a 1989 F350 CrewCab 4x4 w/460 engine, 5-speed trans.
I have had this truck at a shop, they replaced the ignition module, wires, rotor/cap, fuel pump, pulled tanks/blew lines, replaced exhaust.
Still, I have the same problem...when I turn the key, usually the first or second try, the truck will start.
If I take the truck out, the more I drive the truck, each time I turn it off and drive again, it seems to get harder to start...it takes more turn-overs to start...it is like it's not getting spark or fuel...but, the mechanics swears it shows pressure when it's turned over and getting spark...
He thinks it must be the coil.. I have the truck now, as I needed it.
I would like to replace the coil myself and would like to know what would be recommended? If I could get a better aftermarket coil, with stronger spark, if that would gain me somthing also, I would like to go that route, but not get too much $$ into it.
Any suggestions would be greatly appreciated!
Rick
Old Jan 4, 2010 | 11:45 PM
richardfine
Try again..I might even get a reply...
Hopefully someone can help?
Rick
Old Jan 5, 2010 | 10:01 AM
mark a.'s Avatar
mark a.
Did you chech the wires at the coil. Sometimes they get brittle and crack right where thay go into the conector.
Old Jan 5, 2010 | 10:22 AM
richardfine
New wires...first thing I did was buy new wires rotor/cap...
Rick
kalpesh
24
Dec 7, 2011 09:13 PM
ponypower
Apr 3, 2011 02:22 PM
conderd
Dec 29, 2010 09:31 PM
tdy
Dec 14, 2006 09:10 AM
