getting better throttle response and performance
Old Dec 17, 2009 | 03:43 PM
darthice's Avatar
darthice
Hey all I was wondering if i could ask what everyone has done to thier trucks to get better performance and throttle response out of them. I have a 92 f150 with a 5.8l and a E4OD tranny. I was planning on (eventually piece by piece) putting a shift kit in the tranny, doing a mass air conversion, putting on long tube headers, putting on an edlebrock performance efi intake, putting in a snorkel tube off a i6. Is there anything else anyone thinks i should do to it?
Old Dec 17, 2009 | 03:56 PM
lew52's Avatar
lew52
The shift kit will help , the LT headers are a good improvement , intake is good , i wouldnt worry about mass air unless your going to do heads & cam , 1.7 rockers will help and advance the timing a few deg , underdrive pulleys E fans are good .... Lew
Old Dec 17, 2009 | 04:16 PM
darthice's Avatar
darthice
Is there a writeup on how to advance the timing i havent done that before. and also can you give me an example of underdrive pulleys thanks! I know alot but i will not try to act like i know everything because there is so much to learn about these trucks
Old Dec 17, 2009 | 04:53 PM
lew52's Avatar
lew52
The base timing is set at 10 deg BTDC with the spout plug out , you can set it to 12-14 most of the time as long as it dosn't ping , Something you have to play with sometimes . The underdrive pulleys are just different sized pulleys that slow down the accessories to free up some HP , they make them for the mustang but will work on the trucks to ....
Old Dec 17, 2009 | 04:59 PM
darthice's Avatar
darthice
so basically set a timing light up and basically advance my distributor a little bit
Old Dec 17, 2009 | 05:14 PM
lew52's Avatar
lew52
Yes thats it , good little gain for free ...Lew
Old Dec 17, 2009 | 06:21 PM
quicklook2's Avatar
quicklook2
remove the spout before messing with the timing.
remember to put it back in.
Old Dec 17, 2009 | 07:33 PM
phoneman91's Avatar
phoneman91
4.10 gears would perk it up.
Old Dec 17, 2009 | 10:15 PM
97FRD1TN's Avatar
97FRD1TN
Negative on the underdrive pulleys for a mustang working.I tried that once and I kept eating belts.The pulleys didn't quite line up.
Old Dec 17, 2009 | 11:59 PM
rla2005's Avatar
rla2005
Valvebody from thePUNISHER is the best way to go. MAF...maybe if you are changing the cam and heads to something more aggressive. Headers are a good suggestion too. If you have a 4x4 consider shorty headers and a 3" y-pipe and a single 3" exhaust.
Gears, did someone say gears? Never fear the gear. Always high on the list for any performance build. Edelbrock truck intake...not high on my list. Better than the factory 5.8L EFI intake, but not by that much for the money spent. It's designed for use with factory E7 heads. I am not not a big fan of under drive pulleys on a daily driver.
Old Dec 18, 2009 | 04:54 AM
lew52's Avatar
lew52
.....Thats the first time i heard that ? I use them on my 302 & they line up perfect , mabee the 351 is different or year specific ? I know if you remove the air pump & don't use the idler pulley it can cause problems . I have heard people on this form use the pulleys on the 351 with no problems ....Lew
Old Dec 18, 2009 | 04:55 AM
lew52's Avatar
lew52
Yep gears are good to ....
Old Dec 18, 2009 | 05:30 AM
lew52's Avatar
lew52
I don't like to give bad info so i double checked my self , went to summit racing . com , the pulleys fit, 86-96 underdrive pulleys for 5.0/ 5.8 , same part # as 5.0 mustang , trick flow 6 grove , 3pc set ..TFS-3400.....Lew
Old Dec 18, 2009 | 09:13 AM
rla2005's Avatar
rla2005
Thanks Lew. I know we can always be assured you research your info.
Old Dec 18, 2009 | 09:25 AM
lew52's Avatar
lew52
Yeah i just wanted to make sure , i use them on 302 in my truck but i never used them on a 351 , but they are the same ...
