As long as it has prongs and not poles, it looks like a standard switch to me.
In case you can not find an exact part number, I am pretty sure they will interchange with later models, the only thing being the connector in the back is different. You can grab a later model switch with harness from a junk yard and just cut the wires off and then splice it into your own harness.
Now, knowing most Ford switches are the same in the same year range for FSB, F series, E series
