Drive shaft orientation
Old May 2, 2000 | 06:47 PM
tuffguy's Avatar
tuffguy
I have a 78 F-150 4X4. What is the correct orientation of the rear driveshaft? Should the slip yoke be at the rearend or the transfer case? Also, my truck is a long wheel base, should I have a CV joint? The truck is lifted 4 inches. Thanks.
Old May 2, 2000 | 08:06 PM
BJs77F150's Avatar
BJs77F150
I have a 77 F150 with about 5"s of lift and my back driveshaft has a Cardon bearing at the Transmission and the slip joint at the back rear end. Not sure if this is correct, a local mechanic says he has seen them both ways. But he said that the Cardon is needed with the lift. Hope this helps.
BJ 77 F150 Flairside 400/C6
Old May 3, 2000 | 04:49 AM
Chuck P.'s Avatar
Chuck P.
The slip joint should be at the diff, the "breather" is on the end of the short shaft, to run it at the 'case would allow water/dirt to lay in the splines(rubber seal on slip end). As long as you can keep the angles at the u-joints close to the same on both ends of the shaft without binding when at full droop, you'll be ok with what you have(although, more angle=less life). If the angles get to extreme, then you might want to consider a double(CV)at the 'case, then the angle into the rear should be as straight as possible. They do make shims that go under the springs to adjust pinion angle. CV's are considered a must on lifted short wheelbase trucks. Hope this helps!
79 F-150 4x4 Flairside SWB w/3" lift
Old May 3, 2000 | 07:48 AM
Ben_2's Avatar
Ben_2
lmayer460
Apr 23, 2015 06:56 PM
Blucifer
Aug 28, 2014 07:14 AM
suzbandit987
1983 - 2012 Ranger & B-Series
Feb 22, 2013 11:14 AM
REAPER4206969
15
Oct 23, 2011 04:28 PM
LARIAT 85
Sep 10, 2008 04:04 PM
