Just installed a rebuilt 460 in my 1987 F-350, in the morning the truck starts fine and runs great. Runs with the temp right in the middle of gauge. Once I have stopped and shut the truck down and try to start again the starter barely turns it over. If I wait till the truck cools down, over 2 hours the truck starts fine again. Is this due to the motor being new? Ive only put probably 20 miles on it at this point and it's not even broke in. Also I have noticed the temp gauge needle is further to the right when the key is in the off position. When its cooled down it's back to the left position. My oil gauge is pegged to the right when the key is off but when it's running it's in the middle and moves a bit either way. I will be talking to the Machine Shop that built the engine to see what they have to say about the start problem later today.
thanks for any advice,
Rich
Rich
For the starter issue first - do you have a ground cable from the engine to the frame and the battery to the frame? If not, that would be the first thing to fix. Next check the cable connection for the starter at both the starter and solenoid ends for corrosion - if there are any signs, either clean it up if possible or ditch it and get a new one. If none of that works, have the battery tested and the starter tested, even if new.
Now for the fun part about the gauges. The oil pressure gauge is a glorified idiot light, nothing more. If there is 7 psi or more IIRC, the needle will move to the normal range. What this means is that you cannot use the factory gauge to read oil pressure correctly. There have been posts in the past about what parts and pieces can be used to change the gauge to a "real" gauge. I remember seeing them years ago....I believe the temp gauge problem could be due to a ground issue with the sender - if there is teflon tape on it sometimes that can prevent a good ground for the sensor, or maybe it is bad....but personally I wouldn't worry too terribly much about it. If you are concerned, you may want to put some mechanical gauges on it to see what it is really doing.
Re: your slow cranking, If your grounds test good. BTW, The grounding boss is at the bottom front passenger side of the block.
The DuraSpark II box has an ignition retard built in. Check the Red & White plug connecting to the module. The white wire should have voltage while cranking over.
This retards the timing and reduces load on the starter.
The '87 model still has an actual oil pressure sender at the center rear of the intake manifold.
The -check engine- idiot light will come on if oil pressure drops below 7 or so psi but checking my stock gauge against a mechanical gauge shows full scale at almost 80 psi and hot idle just below 30.
You will notice your idle speed increase over the next few weeks as the engine loosens up.
What does your battery voltage read at the battery posts and at the starter?
Battery voltage while running is 13.5 to 14 so it's charging. Voltage not running 12. Havent checked voltage at starter, will when I have someone to turn the motor over.
Good luck!
My battery is grounded to the engine block . Would you use the Ohm part of meter to check grounding? I may need to run a ground from frame to engine block I did wrap my sensors in teflon tape so this may be causing the strange reading. I do have an actual oil sending unit on the back of the intake manifold. I will probably put a mech. gauge on to see how it lines up with the factory gauge.
Went to the maching shop that built the engine and they say to retard the timing a bit and that should help. Once motor is broke in move the timing where you think it's best.
You have a very discharged battery if you only get 12 volts not running. Running should be more like 14-16 volts in lot of systems.
Charge your battery so it is 12.6+ (fully charged) and see if that makes a difference before going farther.
+1
I'd start there. Also, if you use an ohmmeter for anything, pull the battery cables first.
I'll check the red and white wires tomorrow, I'm interested to see if I have this set up. If so then I should not have to retard the timing. I did time this by ear, need to get a timing light and check. Can't wait for it to loosen up a bit.
