Trans help needed...
Old Dec 16, 2009 | 12:40 PM
hogdogs's Avatar
hogdogs
My father's '87 F-350 was making a squallin' noise... Sounded like possible brake issue to others so I went to t-shooting. Jacked up truck and ran idle thru gears,.squall was not present, I was able to make it sort of show a growl by stopping one tire so I had him ride the brake. Seemed to make noise from transmission... I pulled the drain and poked a magnet in and pulled what looks like a 1/4X1/2 roller bearing roller. So off came the PTO cover... Didn't find more large pieces but a gob of filings withsome small shards...
Is the trans in bad shape? It is a 4 speed Borg Warner... He would like a 5 speed so a used trans is a possibility.
He wants to stay direct swap as in no drive shaft cutting or swapping if possible.
Here are the numbers off the tag.
E6T3-LA F248 <(hand stamped) 2
13-09-066A 53134
So what would be a GOOD STRONG 5 speed? This is a 2 wheel drive dually that WILL be pullin' trailers.
TIA,
Brent
Old Dec 16, 2009 | 01:02 PM
Fishin76's Avatar
Fishin76
Your T-19 needs rebuilt. obviously. Your not gonna swap trans to a 5 speed without driveshaft work. the trans are not the same length, IIRC.
You can swap in a ZF 5 spd. just get the trans and the rear shafts and hardware from a 88 dually 5spd. You'll need a diesel trans, or a 460 trans (and modify it to fit).
The driveshafts have to come out anyway to put the new trans in, so it's really no big deal to swap driveshafts
Old Dec 16, 2009 | 02:33 PM
starmilt's Avatar
starmilt
460 does not fit.
Old Dec 16, 2009 | 06:19 PM
hogdogs's Avatar
hogdogs
What should I expect for a bearings and seal kit? What are the "absolutely required" specialty tools to go into this?
I am quite ept but we do have a local guy who will do it if I cannot.
I will be doing the in and out no matter what...
What kind of price have these jobs run if the gears and such are fine?
Brent
Old Dec 17, 2009 | 05:26 AM
hogdogs's Avatar
hogdogs
One more look, Please...
Thanks,
Brent
P.S. I will be out most of the day.
Old Dec 17, 2009 | 06:14 AM
starmilt's Avatar
starmilt
Not sure on a rebuild kit but the T19 trannys usually last longer then the truck and are plentyful and cheap used. PS gas or diesel bolts up but the gas tranny has the same high gear but a lower low gear.
Old Dec 17, 2009 | 09:42 AM
Fishin76's Avatar
Fishin76
See post #9 on this thread at oilburners.net
Oilburners.net
I never said it was easy to put a gas zf on a diesel, just that it was possible with modifications.
On replacing the T-19, You'll want one from a diesel truck. they normally get the 4.02:1 first, which is good for our diesels. Some came with 5.xx :1 ratio, and almost all gassers had 6.32:1 first gears (real granny tranny). The latter effectively makes the 4 speed a 3sp in everyday driving, But you could break driveshafts with the 6.32:1 ratio pullin stuff.
A junkyard replacement will be cheaper and easier.
burnsbm0796
Sep 18, 2014 01:34 AM
Landfill90
Aug 26, 2014 07:59 PM
flipboard7431
Apr 30, 2014 07:30 PM
wantaford
May 11, 2010 10:43 PM
87black150
Apr 6, 2007 07:51 PM
