brakes dragging
Old Dec 16, 2009 | 08:58 AM
rockdawgone's Avatar
rockdawgone
Unhappy brakes dragging
I just replaced my front calipers and pads I have both books and they say after this job Ill need to recenter the proportioning valve well niether book say how I read the brake section front to back and can not find how to do this anywhere brakes are sticking already need to replace front pads again
any help would be appreciated
Old Dec 16, 2009 | 12:05 PM
powersmoked's Avatar
powersmoked
I use to own the same truck. I have the haynes manual. I looked thru it and did not see where they called for that precudure on the 1996. Just the ealier models. haynes chapter 9, section 11, paragraphs 13 and 14. I looked thru it quickly if i have a chance to look again later i will. is the brake light on? Do you have RABS?. Did you bleed the rears also?
Old Dec 16, 2009 | 12:09 PM
powersmoked
did you actually jack the car upa nd try and turn the wheel and it was stuck? how long ago/mileage did you change the pads/calipers?
Old Dec 16, 2009 | 12:29 PM
Lazy K's Avatar
Lazy K
To add to what PS says, is it both fronts dragging or only one? Usual causes are sticking caliper slider pins (a little grease helps here), sticking caliper pistons or bad flexi brake hose.
2004 - 2008 F150
17
Oct 17, 2011 01:38 PM
Vijay
Mar 24, 2011 07:20 PM
Mormakil
Aerostar
Jul 12, 2007 04:16 PM
Wiskey6
Jun 22, 2005 12:28 AM
AeroGurl
Aerostar
Jan 1, 2004 11:48 PM
