No throttle response
Old Dec 16, 2009 | 08:27 AM
kcphillips's Avatar
kcphillips
Looking for some help fellas...have a f250 Harley edition 2004 6.0 diesel that has at intermittent times either no throttle response or when it does start really labors to maintain an idle ....thinking it may be the ICP or is it the throttle pedal assembly...hoping it is not the latter as I have adjustable pedals and the throttle assembly is $700 from dealer!!!!! Any suggestions???? Or alternative sources for pedal assemblies???
Old Dec 16, 2009 | 08:31 AM
gearloose1's Avatar
gearloose1
Check EGR function... check for Codes.
Old Dec 16, 2009 | 08:40 AM
kcphillips's Avatar
kcphillips
egr was replaced 8 months ago....dealer ran diagostic and got P2284 code but couldnt verify as they wanted $575 to replace ICP (have an 04 engine with this sensor on the valve cover on passenger side) told to forget replacing as would do myself for the $147 cost of part.....but from what am reading on other posts thinking it may be the throttle assembly??????
Old Dec 16, 2009 | 08:55 AM
gearloose1's Avatar
gearloose1
What codes are you getting now?
Old Dec 16, 2009 | 08:59 AM
kcphillips's Avatar
kcphillips
the last code I got was P2284
Old Dec 16, 2009 | 09:16 AM
gearloose1's Avatar
gearloose1
Get a code reader on it and tell us what codes are there now.
Not when you last had it in the dealer.
Old Dec 16, 2009 | 06:16 PM
barnbridge's Avatar
barnbridge
I've had erratic, low idle and it was the ICP sensor. Replaced that myself. Also had dead pedal, truck would drop to idle and stay there. Restarting would fix. That was the pedal assembly, replaced under warranty. I'd try the ICP first. Could you replace the adjustable pedal with a non adjustable one?
Old Dec 16, 2009 | 07:05 PM
cheezit's Avatar
cheezit
I would suggest that you may want to replace the icp connector at the same time. We see a lot of both issues causing the p2284.
Old Aug 18, 2010 | 11:49 AM
craneman0426's Avatar
craneman0426
what do you do if the truck is showing no throttle response and there are no codes? under warranty and dealership refuses to do anything but check codes.
Old Aug 18, 2010 | 06:28 PM
cheezit's Avatar
cheezit
take it to a different dealer.
Old Aug 19, 2010 | 08:47 PM
Funtrucker's Avatar
Funtrucker
I have an 2004 F350 that 20,000 miles ago had a reman engine installed after #5 injector overfueled and melted multiple things. Anyway, I had intermittent problem almost same as yours; lack of throttle response from idle, or idle dropped lower than should. I could kick it up and it ran fine once it got up to 1500rpm plus. It cleared up and I drove it for 400 miles then after sitting home for couple of days it had same problem. But this time it would not start after I found I had the problem again. I talked to another mechanic who suggested I leave the ICP sensor installed. I believe the FICM would just go into default mode (luckily its a later ICP installed in right valve cover), remove the connector and try it again. She started right up and so far today after driving couple of miles and restarting multiple times its okay. It did not throw a code prior to, but of course now unplugged it gives me P2285 ICP low sensor circuit. I will keep trying to fail it but will replace ICP next. So if it will help anyone try unplugging it first.
Dave
guitarpicr
Feb 26, 2017 08:02 AM
DSMMH
Jan 22, 2017 03:54 PM
blageurt
Ford Truck Parts for Sale
Jul 13, 2016 09:39 AM
mccorpa
2009 - 2014 F150
Apr 21, 2016 03:22 PM
Olafs 7.3 ex
May 13, 2015 01:50 PM
