Sponsored by: Real Truck
ignition lock
Old Dec 16, 2009 | 04:58 AM
gafftbk's Avatar
gafftbk
ignition lock
1999 F250 light duty 120000 miles. The end of the ignition lock broke of so I removed it but I also had to remove the bearing cap, bearing, and the gear in order to get the piece that was broke off. I reinstalled everything the way i thought it was suppose to go but it won't start. Could I have put the gear or bearing in incorrectly? When I turn the key forward I don't believe it is going all the way into the run position. 1 because it doesn't start and two i can't get the ignition lock back out. Does anyone have a picture of the correct alignment of the bearing and the gear.
thanks
Old Dec 16, 2009 | 06:10 AM
Pitcher's Avatar
Pitcher
Ya know, I don't know if they still do it, but I have had AAA replace an ignition lock or two for me free under the basic coverage. However that was about 10 years ago, so I don't know if they still do?
