intercooling options.
Old Dec 16, 2009 | 02:31 AM
mongo12's Avatar
mongo12
So i was reading diesel power (the bible) and saw a article on ATS' intercooler for the 94-97 powerstroke. it looks good but i'm hoping someone has this and can give me an idea on how it works while towing. Since i bought my 97 for towing and hauling crap to the dump here and there.
Old Dec 16, 2009 | 03:07 AM
Oversize's Avatar
Oversize
I dont know how well it works, but I live near ATS here and have been to ther shop a few times, and it has been my experience that when talking with them and seeing their prices their stuff may work but it is really overpriced for what you get. Especially when it comes to intercoolers, the only one worse on pricing is banks. You can easily do what a lot of people here do and retrofit a intercooler out of a SD for a whole lot less $ and be just as good.
Old Dec 16, 2009 | 07:56 AM
jeep1947's Avatar
jeep1947
Use the search feature there is a good writeup on using a cooler from a 6.0. Like Oversize said results are the same for less money.
Old Dec 16, 2009 | 08:12 AM
Fullcrew7.3's Avatar
Fullcrew7.3
From a 6.0 or a 7.3 superduty.
Old Dec 16, 2009 | 09:43 AM
MagKarl's Avatar
MagKarl
Do you have EGT trouble with your current setup? Unless you have a chip, aftermarket injectors, or both, you probably won't see much benefit from an IC other than a lighter wallet.
Old Dec 16, 2009 | 11:40 AM
wmiller's Avatar
wmiller
I wouldn't worry about the intercooler unless you getting bigger injectors. With wild tunes and intake and exhaust i had a hard time getting over 1150* unless i was pulling a long grade (several miles) and even so just back out a little than get right back in it.
If you do intercool i would get one from a 6.0. they are bigger and more efficient than a late 7.3. I think for mine i got a take off unit from banks and a set of pipes from both a 7.3 and 6.0 and between the 2 made them fit mine
Old Dec 16, 2009 | 12:09 PM
plowhand's Avatar
plowhand
Playing in the Dirt
You could always go with a water to air intercooler set up from $200 to $600. Air to Water Intercooler
Old Dec 17, 2009 | 05:36 PM
mongo12's Avatar
mongo12
i've heard about puting a 6.0 IC in the truck but how bad do i have to modify the core support to fit the tubes? The Methanol injection is not a bad idea... will look into that. what is a good recomendation?
Old Dec 17, 2009 | 05:48 PM
wmiller's Avatar
wmiller
you just have to cut 2 holes in the support and make up mounts to bolt it
Old Dec 17, 2009 | 05:53 PM
c00nhunterjoe's Avatar
c00nhunterjoe
i run the 6.0 cooler with custom made tubes from 6.0's and 7.3's. i am happy with it and have virtually no money tied up in the set up
