Sponsored by: Auxito
mass airflow sensor help
Old Dec 15, 2009 | 09:08 PM
dudeiscool654's Avatar
dudeiscool654
Hi everyone! I've had my 2000 f-150 since april and it's finally starting to have stuff break on it. I had coil #1 go down on me and when i replaced it I started looking under the hood and check things out. I found a wire stuffed down with a piece of plastic on it. Not knowing what it could go to I asked a friend and we figured out it was the connection to the mass airflow sensor. Then we realized there isn't one on the truck at all. There is a chip in the connector where the maf would go. My question is where would be the best place to get a replacement?? i want to run a mass airflow since here in ohio it's starting to get cold and the truck is startin to run a little rough. Thanks for all your help.
Old Dec 15, 2009 | 10:22 PM
DJPRacer58's Avatar
DJPRacer58
get a used one at a junk yard
Old Dec 16, 2009 | 05:53 AM
torkum's Avatar
torkum
X2 on the junk yard, just make sure to clean the 2 wires inside before install. Be careful on the cleaning and use a MAF approved cleaner.
Old Dec 16, 2009 | 06:58 PM
ventureman86's Avatar
ventureman86
Mass air flow sensor replacement
The others are thinking the same as for the junk yard. You can get it other places but you will pay way more. When you put it on some one suggested cleaning it. I found a step by step procedure on this web site for cleaning mine. I used contact cleaner on mine and wiped it carefully. That fixed my problem as I run a K&N air cleaner and when you over oil it that will foul up your sensor where you get a 171 and/or 174 code. A simple cleaning will fix you up.
NotFar
1983 - 2012 Ranger & B-Series
Apr 21, 2013 08:30 AM
rusty70f100
Jun 9, 2005 04:54 PM
jwh
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 9, 2004 08:10 PM
abendx
Apr 9, 2002 07:17 PM
amsnss
18
Sep 2, 2001 05:04 AM
