e350 fuel leak
Old Dec 15, 2009 | 08:51 PM
thedieselkid's Avatar
thedieselkid
e350 fuel leak
fuel is leaking all down the rear intake manifold when van is running.
I can't see where it's coming from. Somone said it maybe hose or orings.
Do i have to remove the turbo to get access to the fuel bowl?? It's really tight in there and i can't see ,uch let alone get my hands in there.
thanks
Old Dec 15, 2009 | 09:48 PM
wheelie31's Avatar
wheelie31
Theres lots of fuel hoses connecting to the fuel filter housing, Most likely one of those is the problem. it takes about 30-40 min to pull the filter housing and you dont need to take off the turbo. Id replace all the rubber lines and that would be a good chance that fixes your problem.
Old Dec 15, 2009 | 09:58 PM
scatgo's Avatar
scatgo
The fule pump is between the bowl and the turbo. There is a weep hole under the pump that can leak. There are two hard lines that go from the back of the pump to the back of the heads that can leak. You aslo have sensors on the fule bowl that can leak.
Old Dec 15, 2009 | 10:08 PM
mrblonde108's Avatar
mrblonde108
thanks i can't see anything. i guess i'll have to take off all the airfilter crap and turbo hoses and go from there. i'm thinking maybe fuel pump weep hole because it leaks when its running
Old Dec 15, 2009 | 10:14 PM
97250hd-earl's Avatar
97250hd-earl
also check the vacuum switch on the fpr. unplug the wire and see if there is diesel fuel on it if is replace it.
Old Dec 15, 2009 | 10:16 PM
mrblonde108
What's the FPR?? if the fuel pumps leaking can it be fixed?? they're expensive.
Old Dec 15, 2009 | 10:26 PM
97250hd-earl
fuel pressure reglator,
Old Dec 15, 2009 | 10:28 PM
c00nhunterjoe's Avatar
c00nhunterjoe
if it only does it when running then the most common leak in teh valley is teh weep hole on the fuel pump, especially if it just started leaking in this cold spell
Old Dec 15, 2009 | 10:41 PM
bruno2's Avatar
bruno2
I didnt see the yr make model of van . Does it have the mechanical pump or the electric ? The fuel pumps are expensive no matter which one . The mech pumps are two stage pumps . The first stage pulls the fuel from the tank. The second stage pushes it through the filter and supplies fuel system with the pressure needed to run . I have had a couple of the pumps leak .
If its the mech fuel pump there are two metal gaskets on the back where the banjo bolt enters rear of the pump . They may be stuck to the pump or bolt . DO NOT LOSE THEM. The new pumps dont come with them and they are probably a salvage part . My salesman at Ford cant find them as a part that is stocked . When you get the pump off you should be able to tell if it has been leaking out the weep hole .
Old Dec 15, 2009 | 11:53 PM
mrblonde108
its a 1997. if it;s mechanical what does it run off??? usually they run off camshaft but wouldnt it be on side of engine??
Old Dec 16, 2009 | 12:32 AM
rodneywar's Avatar
rodneywar
It runs off the camshaft which is in the center on the engine just under the valley.
Old Dec 16, 2009 | 07:14 AM
MADVAN's Avatar
MADVAN
Pull off the dog house and look for the leak
from the back of the motor.
Bill
Old Dec 16, 2009 | 10:29 PM
mrblonde108
I pulled it off can't see where it's coming from. ibut i can see the puddle forming up toward back of fuel bowl. I guess ill have to take all the turbo duct work off.
Old Dec 17, 2009 | 08:36 AM
97250hd-earl
look for the vacuum switch, it"s on fuel pressure reglator bolted to the fuel bowl it has a wire pluged on it on the driver side,
Old Dec 17, 2009 | 10:48 AM
scatgo's Avatar
scatgo
The vacum switch is on the back of the bowl on my truck. Not sure when they switched it over to the FPR.
