400 vs. 460
Old Dec 15, 2009 | 07:43 PM
SNSTER's Avatar
SNSTER
400 vs. 460
Howdy ladies and gents. I'm sure this has been beat to death but how many have built there 400 for power instead of just swapping in a 460. Those of you who built the 400 what is your combo and power numbers if you know them. I'm looking for the 425-450 range and dont know if I should build the 400 or buy a 460 and build it. will mainly use this as a driver and to pull a 24' boat to the lake. thanks
Old Dec 15, 2009 | 07:59 PM
fordtech08's Avatar
fordtech08
I had a built 400 in my 70 f100 right after I blew up my 460 I enjoyed the 400m a lot better I was able to run the 400 on 87 octane and it got better fuel mileage plus at over 400 horse and torque the truck had all kinds of wheel spinning power
Old Dec 15, 2009 | 08:04 PM
SNSTER's Avatar
SNSTER
Hope there is no wheel spinning. sure the 35's would break axles
Old Dec 15, 2009 | 08:12 PM
fordtech08's Avatar
fordtech08
that could explain why my auburn posi acts like an open dif now
Old Dec 15, 2009 | 10:00 PM
smokeyb97's Avatar
smokeyb97
My engine is a 351M/408ci after .030 overbore. I'm using a Comp 255deh cam, Edelbrock Performer 400 intake, Edelbrock 600cfm carb, Scorpion roller rockers, TMI pistons, with OEM heads. Engine dyno'd at 339hp@4300rpm and 478ft/lbs@2900rpm.
Old Dec 15, 2009 | 10:10 PM
kentuckycrew's Avatar
kentuckycrew
Ive had both and have heard the huge mob that is opposed to the 351m/400 But personally i like em esspecially with a few simple mods. Do i like them better than a 460? no probably not, but you can still get pretty good power out of them.
Sorry im rambeling and still havent really helped you any
Old Dec 16, 2009 | 01:29 AM
F350BRCO's Avatar
F350BRCO
I've also been happy with my 408. Only upgrade I added is an Isky mega cam, and a 750 Holly double pumper. All other components have been new stock parts. Run the motor 5500-6000 RPM on the weekends and average about 12 MPG's on the highway when running speed limit. I'm able to keep my temp under 200 degrees while my Big Block friends have to shut off their motors due to overheating.
Never put it on a Dyno so I would only assume my HP is over 300.
Old Dec 16, 2009 | 08:27 AM
chilsam's Avatar
chilsam
460 is my choice all the way,Ive had nothn but bad luck with 351m 400.More perf parts for 429,460 family "CJ,SCJ"
Old Dec 16, 2009 | 12:24 PM
Blown 331's Avatar
Blown 331
I can't stress this enough. Swap to a 460 and never look back.
Also are some of you saying boring a 351m .030 makes it a 408? Wow, more like a 357. Thats rediculous.
Old Dec 16, 2009 | 01:19 PM
fordtech08's Avatar
fordtech08
no boring a 400 .030 makes a 408 the 351m and the 400m are the same block with just different pistons and crank
Old Dec 16, 2009 | 01:32 PM
Blown 331's Avatar
Blown 331
Well then why does it say 351m? That would be like saying my .030 429 is 466 cubes.
Old Dec 16, 2009 | 01:36 PM
fordtech08's Avatar
fordtech08
the 351m and 400m are 2 different engines ford used the same valve covers for both the sticker said 351m/400 so alot of people think it's the name of the engine
Old Dec 16, 2009 | 01:39 PM
Blown 331's Avatar
Blown 331
Interesting perspective, I never thought of that. Makes sense.
Old Dec 16, 2009 | 01:48 PM
fordtech08's Avatar
fordtech08
sorry it's just one of my pet peeves when someone calls it a 351m/400 they don't call it a 429/460
Old Dec 16, 2009 | 06:28 PM
SNSTER's Avatar
SNSTER
so why is the consensus that the 460 is so much better then the 400?
